heyheyfifi
New Member
Starting my first build! I'll be making a foamie 6'4" x 8' design on a 4x8 harbor freight trailer. The goals of the project are to be low cost, low weight, and simple construction.
The design is heavily influenced by the Runaway RangeRunner design. They have a curvy roof 42" high on the sides and 46" high in the middle. My design has 45.5" headroom on the low side and 51" on the tall side. The RR is 70.5" wide on the inside and mine will be 73" on in the inside. The people in the model are 5'4" and 5'10".
Using 48" foam sheets I'm increasing the headroom using 2x2s on the edges, which also adds to strength. I will be making the doors (wish me luck!) which will span between the 2x2s. There will be 3 doors. The door on the back end will be a little off kilter because I had already purchased a window before finalizing the design. No galley because it seemed really complicated and the way I camp I don't see it being very useful. We'll be making a chuck box. The framing on the trailer will be made with 2x3s with a sheet of plywood on both sides, leaving room for the tires after removing the fenders. There are 2x4s on the corners for strength and to add some D-clamps to tie down a canoe or a few kayak to. The foam on the sides will be 1.5" and the foam on the roof will be 2". I'm estimating the total weight of the empty camper will be around 650 lbs, with about 150lbs of cabinetry (still thinking through), and few hundred pound of our stuff, with a tow vehicle that can pull 1,500 lbs.
I'm hoping to finish this in 2 months or less, we'll see what happens!
