Multi-purpose Build started
Thread Summary
Summarized on:
A member has begun constructing a custom aluminum utility trailer designed to handle up to 3,000 lbs, with the flexibility to drop in a pod for use as an enclosed trailer—ideal for snowmobiles and other gear. The build features a 140x72-inch all-aluminum frame, using 2x5-inch channel for the outer frame and 2x4-inch channel for crossmembers, all at 3/16-inch thickness. The builder emphasizes minimizing material waste and is progressing methodically, sharing photos and design updates along...
More...
leblanda
Advanced Member
Joined
May 20, 2019
Posts
50
Hi Guys
I know that I I've been around here asking questions for about 3 or 4 years but know it's time to start.
Please be patient as you probably see by the time I start my first question I'm a slow builder because of so many project.
The goal of the build is to build and aluminium frame to be used as utility trailer for 3000lbs that I will drop in a pod in to use as enclosed trailer for snowmobile and other needs.
So tonight, I cut the frame piece of the Aluminium frame.
The build will be 140x72 all aluminium.
The build as of now is 2x5 x3/16 channel for outer frame and 2x4 3/16 for crossmembers.
Here's the pictures
you see at the right the left over from the alu bar, so that is why i'm a slow builder... minimize waste !
Be patient and stay tuned ;-)
Since the frame is gonna be in channel instead of rectangle tube based on recommendation of a experience welder.
I need to make the channel to fit inside the others for the frame outline.
sorry for being so long.
here is the final version of the utility portion with bolted side.
