My experiment with polyethylene.
Modstock
Senior Member
Joined
Feb 1, 2012
Posts
1,216
Awhile ago I stuck a panel of 1" polyethylene under the cargo trailer. The other regular insulation was falling apart.
Looking online it said using 100% silicone would glue it to the wood underneath.
FAIL. There's a brace in the frame that holds it in the center but the edges I glued have fallen down.
By accident at work I think I found a solution.
Using some osb similar to the trailer floor I glued 3 different pieces to see which holds up better. Left to right.
1. ) glued using our yellow contact adhesive
2.)black RTV/ silicone .
3.) Hot glue
Letting this dry and set up for 24hrs before we do the pull test.
Doing the pull test. The hot glue was the winner followed by the RTV/silicone.
Contact adhesive had some resistance but didn't stick to the foam as much.
Pic L to R
Contact adhesive, rtv/silicone, hot glue.
Only downside to hot glue is you have to work fast.
Guess we will see how it holds up to my abuse. 😉
I'll have to try that next time.
Well, the sides fell down again. The construction adhesives didn't work but the silicone seems to stick to the foam.
So I cleaned it up and used a lot of silicone along with a plastic glue.
We'll see how that holds up.
