My first build
Philou
New Member
Joined
Jul 31, 2025
Posts
6
Location
Levis
I just finished my first build. I was inspired by many threads on this forum and wanted to share and explain what I did. 5’ x 8’ aluminum custom built frame. Everything is made out of birch (Baltic) plywood and red oak for the timbers. Floor is a sandwich made of 1/4 ply/1.5”foam/ 1/4 ply. The roof is also a sandwich 1/8ply/1/8ply/1.5”foam/1/8 ply/1/8ply. The walls are 1 inch thick plywood. All the exterior is covered with 6 ounces woven fiberglass and clear epoxy resin. Outside paint is polyurethane, the exterior varnish is Epiphane marine varnish. All the inside is varnished with a polyurethane water based clear. All the hinges and latches are marine grade stainless steel. I put 2x 100watt solar panels with a mppt connected to a 100Ah Lithium battery and a 20A battery charger.
Aluminum frame with 13” tires
Floor covered with fiberglass before flipping
Sides screwed into the floor.
Roof framing
Insulation
Roof skin gluing
Finished with the fridge on hinges.
Looks absolutely amazing! Do you have any more pictures? I'd love to see some details of the various aspects of the trailer.
Yes, I have many more pictures. What details in particular are you looking for?
New posts
