My Thoughts On A Off Road Foamie
Here is another video of my foamie in off road action.
[youtube]zdINI5DeZwc[/youtube]
This year is winding down so it is time for some more thoughts on the foamie.
The foamie has worked out great this last year. I took it on quite a few long distance trips. I had anticipated rougher roads though so a bit disappointed in that. Lots of wash board though, which in reality is probably the worst conditions and a good test to glued joints.
The biggest issue I have found is gravel roads. Kicked up rocks basically sandblasts the metal parts and bigger rocks can dimple the foam/canvas. I guess mud flaps on the Jeep would be good, but I am looking at the trailer to be self protecting. Some thoughts are in mind for that. The gravel also tends to get lodged between the trailer body and the fender support. The fenders flexs when going down the road which allows the gravel to lodge more and more into the foam. I Think this is a bigger issue since I had to raise the fenders 2" to accommodate the 13" tires. Better fenders are probably the solution for this and if done right will cover the damage the gravel has done to the foam.
I have found that the 13" tires were a big improvement over the stock 12" tires. More so than I even thought. I am still looking to go bigger, but it is not as near the top of the list as it was. I still have plans to go to at least a 31" tire and some other modifications I had planned will have to go on the back burner till this modification is done. At this time I do not know how high the trailer will sit with 31" tires since with that modification I will probably be replacing the springs to a longer/shackle style springs. I will also at the same time be installing a new axle to support the larger wheel/tire combination.
2"x2" steel tube for a back bone has been a improvement for off road. I could tell right off a big difference in trailer manners on and off road. To be honest I think all HF trailers should have this modification even if still running the 12" tires.
I am working on a couple of roof rack system that I think will work. They are two different designs and really depends on the way I want to go with another thought.
A tongue box or carrier is on the list as well. This will depend on heating and cooling options that are also in the works.
More thoughts coming as I think of them, George.
I like what you're doing here, George. Great work! I have never subscribed to a youtube channel, but I may need to start.
I have two channels.
My overlanding/4x4 channel. https://www.youtube.com/channel/UCYuRx2 ... wVwZJ5oztg . This follows my adventures out and about with and without the trailer.
My Bug Out Trailer Channel https://www.youtube.com/channel/UC3xVuH ... SiploqPyrw . This is a step by step video series on how to build a very basic foamie trailer. It is basically the same trailer that I am using for my Overlanding/4x4 trips.
Thanks for watching, George.
Wow! Over 2 years since I posted here last so I guess it is time for a update.
I have been using this trailer hard the last two years. It has followed me around on some epic adventures. You can check out those adventures here https://www.youtube.com/channel/UCYuRx2 ... ztg/videos if you have not already. I am happy to say that I finally did find some rough roads to test the trailer on. It has held up just fine.
I did finally break a leaf spring. I can not say that it was the springs fault for sure since I did have two of the leafs flipped for a softer ride. At that time I did opt to install a soft ride spring setup made my Compact Camping Concepts https://compactcampingstore.com/product ... spring-kit . This was a great upgrade to the suspension. It rides so much better now and I don't have to listen to the clicking of the slipper spring anymore.
There has been no other mods at this time except for the springs.
I am planning to install rear side cargo door and some shelves soon as well as a awning. I hope to have those modifications done before April.
Well that is all for now.
John61CT":3nlor43a said:
Any thoughts on replacements for Glidden Gripper since that's been discontinued ?
I have been using Valspar Bonding Primer lately. It cost a bit more than the old Glidden Gripper (could be current economics though). I find it to be very similar to the old Glidden Gripper and I am very satisfied with the results.
You use the Valspar to initially bond the canvas to the xps instead of Titebond II in your pmf?
In my builds I sand the xps smooth making sure I get rid of all the shinny surface of the foam. Then I prime with bonding primer and then apply the canvas with TBII. I find that the bonding primer bonds better to the foam than TBII. Then I apply the canvas with TBII to the bonding primer. TBII bonds real well with the bonding primer. I have been pretty satisfied with this technique.
I don't think I would attempt to apply canvas with bonding primer alone. I just don't see how you would get a good result with that technique.
Mr George,
I enjoying following your trips and the stuff you have at Overlander. I tickled me about their feelings about foam it construction.
catsmith":3qfpox94 said:
Mr George,
:thumbsup: Glad you are enjoying the videos! George.
Nanny54 is an ad bot. Amazing how many ad-bots you now meet at actual campsites across the country these days. :thinking: :stompspam:
Ad bot, or just someone using AI to help them compose prose? That's what the world is coming to, self driving cars and mindlessness. Does it have to be so artificially sickly sweet? Where I work is trying to promote the use of AI for better, more efficient writing skills. I will resist vehemently.
New posts
