New 7 pin connector not working properly?
DryHeatDan
New Member
Joined
Jan 31, 2021
Posts
5
I just had a brake controller and 7 pin connector installed Monday and when I went to test the connector with my TTT everything worked properly except the turn signal and brake light on the passenger side. The rear right light comes on when I turn on the headlights but it doesn't respond to the turn signal and brakes. Does this sound like a trailer problem or a connector installation problem?
:NC
Could be either. My gut leans toward it being a trailer problem. You can easily test lighting circuits in the trailer without having it hitched up.
Thank, Rob. Sorry but I'm brand new at this, how do I test the trailer lighting circuits?
There are (three styles) and they fit but dont work correctly together.
Check your light bulb first, one element out of the two would cause exactly this........
tony.latham":7p7a62tb said:
You could check the tow vehicle with a trouble light, but if that's a headscratcher, get one of these:
https://www.amazon.com/Vehicle-Trai...ocphy=9029516&hvtargid=pla-567611324560&psc=1
But if you know of another trailer with known working lights, you could test your new wring job with that. :frightened:
Bet somebody sells one that goes the other way (I deliberately didn't look before posting), but a few years ago, that would have been a neat thing to develop and sell as a little electronics kit:
Little box that takes 12 vdc (maybe from AA cells), and some switches to turn on turn signals, running lights, brake lights, brake, etc.
Tom that is a spectacular machine but YIKES indeed!
DryHeatDan, I'm certainly no pro at this either, I just know enough to get myself into trouble. The item Tony suggested is a fantastic item for anyone who regularly tows to have in their toolbox and it is quite inexpensive. They are commonly available anywhere you find trailer towing accessories. You plug that into the connector and the lights will tell you what things (signal, tail, brake, etc) are working from the tow vehicle side as you activate them.
If your only problem is the stop/tail feature on the right side and everything else works properly that tends to suggest the problem is in the trailer. It IS possible that the bulb in that position just happened to go bad, even though it may have been working fine the week before you had the connector installed on the vehicle. There might also be debris in the bulb socket or a broken wire in that circuit anywhere between the bulb and the connector.
You can also use something like this...
https://www.amazon.com/dp/B07F2GWNR...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
...to test the circuits in the trailer. There are a few different varieties of these. You can use one that contains a small battery to test for continuity or one without to test the condition of a circuit using the vehicle's power.
All things considered, I would first try replacing that one bulb... :thinking:
New posts
