saltydawg-TNT
Senior Member
- Joined
- Apr 24, 2012
- Posts
- 647
Okay I saw a video of a guy who built his own trailer, not tear drop type but travel. He used a product called AluPOLY for his skin, it is use for signs, and kiosk type stuff. It is a panel with 2 Al skins and polyethylene foam board in the middle, the AL skins are pre painted and they offer many colors. The thickness is 2 mm , 3mm, and 6mm I called the place not too far from me for a price, its 78 bucks a sheet for the 1/8 ( 2mm i guess ). They make it with thicker skins as well. https://www.piedmontplastics.com/products/acm
This stuff might be very interesting for skins, they do sell it 62 wide. I would think in the thicker 3mm and 6mm versions it might be a great skin for teardrops as it is semi structural on its own so the bond to a frame would not need to be perfect and still not oil can. Also it can be bent around a curve, or even bent 90 degrees if you route out the rear skin. I am picturing in my head a great way to seal corners for roofs. Basically roof make the roof panel 2 inches wider, then rout out the rear skin of the roof panel where it meets the side way, then bend the 1 inch on each side over the side wall and fix with sealant and some rivets.
Due to the core, it might even be seamable by digging out the foam core for a 1/2 inch on each panel and gluing in a AL strip of the right thickness. Or even fancier doing a lap seam where the skins are offset by a half inch and digging the core out a half inch and using a 2 inch strip to fill it. This would spread the stress of the seam out.
Cost is obviously more than luan, but by the time you had in finishing luan its probably cheaper, and its definitely cheaper than filon.
