No problems with the strength of the shell. The box shape could be more rigid, however. I was thinking for V2.0 I might introduce some gentle curves to the sides and top (no kerfing required.) That would probably stiffen things up considerably. As it is, going to a pair of lighter back doors instead of a single big door should eliminate that issue. Just have to decide what to do about windows.
I neglected to mention that I didn't have time to add hard structure to screw in the stops for the back door and a fold down table under the hatch. I used those plastic screw-in drywall anchors instead, the kind with the deep threads. That worked surprisingly well. The canvas skin provides excellent shear strength to the fastening. You do have to make sure the holes in whatever you bolt to foam sides lines up with the fasteners. I drilled holes in the parts first and used the drilled parts to mark the locations of the drywall anchors. They happen to be short enough to go into 2" foam without coming through the other side.
