Hey all,
Looking for a little foamie advice here. I'm looking to build my first TD, and I'm looking for some general foam info. Originally I was planning a plywood sandwhich construction, 1x2 framing, with foam insulation in the middle, which I picked up as it seems to be the general construction method here. I was planning on painting the outside and using Watco Danish Oil and polyurethane on the inside, to give it a nice wood finish. But yesterday, during my continuing research, I started reading the "grits" construction thread, as well as the general covering thread. Also a thread about how to keep them dry, which Mike started and mentioned his plywood delamination..
As I understand, foamies are the lightest TDs, they are easy to make, hold up really well, and have no chance of rotting/delamination. So I have a couple questions to help understand and figure out what I'm going to do. First off, I've already bought and registered a 4x8 HF trailer, and it's partially assembled. I want just a little over 5', so I can fit a standard queen bed inside and not worry about a custom made bed. I'm planning on doing the Austrialian Sportsman (stretched) profile, with the flat bottom 8' long, and the front and rear curves someone longer then that. I plan on getting a deep cycle battery, so that I can camp at non-electric sites and have lights and a vent fan at night. Towing with a 2005 Kia Spectra, 1000 lb no brakes, 2000 lbs brakes, 160 lbs max tongue weight per owners manual.
1) Although I did want it light, if I go with a foamie, could it be too light for my 1720 lb HF trailer? I.e. springs too stiff for the load it'll be carrying?
2) Building 5' 4" wide or so, I'll need a raised frame to get over the tires. What's the general way of doing this on a foamie? 1x3's or 2x4's like a non-foamie TD and black tar?
3) Framing: Since it won't have regular framing, I have to plan the loads better so I know where to reinforce the foam, correct? I.e. interior shelves/cabnets, galley shelves/cabnets, deep cycle battery mount.
4) Axle position: I'm guessing the axle may have to go further back then a "normal" TD, as the foam weighs less so a galley would be relatively heavier? Is there a standard axle position for foamies? Looking to get close to the minimum tongue weight since I'm towing with a sedan. I'm not planning a super elaborate galley, some counter space, perhaps a small sink, some canned food/spice/general storage, a Coleman white gas stove, cooler.
5) Does anyone do a thin ply, varnish/poly interior for a wood finish with foam construction, or to most foamie builders go with the KISS method?
6) Any other general suggestions that you may have for a foamie/TD newbie?
Also, through Saturday Menards has 11% rebate on all purchases, so if there is stuff I can start buying to start off from there, that's great. I did a little price checking on foam, the pink 4x8' stuff from Owens Corning is: 2.0 in: $26.41, 1.5 in: $19.95, 1.0 in: $14.55, 0.5 in: $9.67. There is also 2" expanded polystyrene for $12.58, but that seems much weaker then the 2" pink stuff.
I'm off to look a little in the foamie section, or perhaps play a little Fallout: New Vegas. Probably both.
<EDIT 2014-02-18> This turned into a personal question thread for me. Discussion of ideas, how to do this and that, and whatnot. I decided on a foamie, and you can see my build thread here.
And as you know , we’ve built many complicated structures out of foam at that “other place”
... but the use of foam for building is now my FAVORITE construction method ... I’m a similar age as Mary of the House of Grits, so we needed a construction method that would NOT require a lot of maintenance or attention... and especially something that would not Rot ... Foam is IT !!!
