Flamesuit on.
I hate to do this before I’ve really explored all the knowledge y’all have already put time into here. Please bear with me, I’ve watched days of YT videos and done a ton of research.
Tow Vehicle:
21 Wrangler Rubicon 4xe (hybrid), 3500 lb rated, Curt has a 4K/400 available.
Basically a street competent rock crawler. 10+” of travel at each corner. Hitch is at 23 bottom 25” top unloaded, expect 2” squat (will aim the headlights), 17” to skids at breakover.
Although it’s probably not the best idea, I want to match the tow wheel setup. 37” BFG KO2 (OWL if that excites anyone), 17x8.5” Racelines at +18mm offset.
My initial mock-up proved I want at least 5x9 for a Queen and reasonably deep galley, still awaiting approval from the Boss. Although not an SE, I do have collegiate level structual(statics) classes and have a reasonable understanding.
I’ll calc before construction, but thinking 2x2x .120 wall steel.
Initial questions:
1. I want a tongue as close to the tow vehicle as possible, with as much clearance for tow vehicle to trailer breakover as possible. Is a “backbone” design the recommended solution? What about a lower trailer (for access/COG) and stepping the tongue up for clearance?
2. My gut is telling me Timbren Tonnes, as the extended travel for the same weight would likely soften the suspension. With 17.5” ish of hub height, and the HD/extended spindles. How critical is matching the tow vehicle track width? I would need to elevate the bed and squeeze the mounting frame in to about 4’ to make this work.
I’m sure these are dumb questions, but appreciate any comments.
Tow Vehicle:
Initial questions:
