Oct 24, 2022 #41 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Timbren 3500HD axle-less suspension crossmember https://youtu.be/a2tv3Ug5yzk
Nov 21, 2022 #42 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Using an EcoFlow Delta mini power station in my camper https://youtu.be/dsUUqOulU7Q
Nov 28, 2022 #43 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Centaflex continuous PVC hinge review and installation! https://youtu.be/hvEbu4fycRw
Dec 19, 2022 #44 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Propex heater unboxing https://youtu.be/p4YI0rbuOXM
Dec 26, 2022 #45 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Mounted a 20lb propane tanks to the tongue! https://youtu.be/lSruBTQ1sME
Jan 9, 2023 #46 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Mounted the Propex heater: https://youtu.be/iwvlhDIqD-c
Jan 16, 2023 #47 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Plumbed and wired the propex heater https://youtu.be/qe_6YQTe2gk
Jan 23, 2023 #48 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Propex hs2000 stealth kit installed https://youtu.be/KsZd-cskDrk
Feb 20, 2023 #49 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Used felt tiles to finish the ceiling! https://youtu.be/tVyHAhiIlfs
Feb 27, 2023 #50 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 One flash fault code on propex heater https://youtu.be/TQ6u2d0zn4c
Aug 24, 2023 #51 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Build progress video: 2 years in 10 minutes https://youtu.be/52MNChM4wfQ?si=lqmlKWstDSimYrpc
Oct 24, 2023 #52 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 extruded aluminum shelves https://youtu.be/AkZjQspZXwY?si=BphzZYPfERCw1O0a
Oct 28, 2024 #53 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Working on the slide out kitchen, here is part one: https://youtu.be/oBpKk6So_4c?si=sbWh4AO7K4WWRx1W
Nov 26, 2024 #54 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 https://youtu.be/lz6hChSOT_8?si=TFifFUxkb6kOB1kz
Mar 26, 2025 #55 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Upgraded to 300W with BougeRv's smaller panels: https://youtu.be/0wLh3OeuJVU?si=i6FRcJNagqL3OUjJ
Aug 18, 2025 #56 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Built some rock sliders for my trailer! $100 DIY Rock Sliders: The Affordable Overland Upgrade
Sep 6, 2025 #57 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Tested out the sliders on the trail! I Built a DIY Trailer for Off-Roading - Is It Durable? https://youtu.be/oLWsDKTHNzo
Feb 19, 2026 #58 OP OP WD wdieck Advanced Member Joined Sep 6, 2021 Posts 53 Added DIY TOPO lines from Wraplander. WrapLander
