ghcoe":1w2fb2lu said:
On my current builds I pre-canvas the interior walls and ceiling panels. Makes things a lot easier.
I agree this is an important technique to use wherever possible. Applying canvas onto a horizontal surface, with good lighting, makes it easily possible to do a perfect job. When adding to the surfaces on the assembled trailer it can be very awkward. It may be hard to see properly and a ladder or step stool might be needed.
I grew up in an urban area. I had a few possessions walk away. I learned that the nicer something looked, the quicker someone would take it. I have since learned that rural places are no better.
Years ago we visited Amsterdam where bicycle theft is rampant. I noticed people would never consider parking a nice looking bicycle outside. Everyone competed to have the junkiest looking (albeit properly maintained) bike; they last longer. Maybe this trailer is safe?
I am glad I resisted adding more windows. The windows in the doors are plenty for our needs and climate. We don't spend time in the trailer during the day. The plexiglass window panes can be removed for better air flow and stowed between the wall and the cabin mattress.
We bought a rechargeable fan to provide ventilation during warm weather that can be hung on the window space. We have used it only once but it ran all night and still had enough charge for more nights. It has a USB port for charging that allows topping up with electrons en route.
Although the window screens work perfectly to exclude biting bugs, I noticed at the height of summer bug season, there are plenty of very small bugs that can still get through.
To paraphrase JBS Haldane:
"God must have an inordinate fondness for insects. He created so many varieties!"
To weigh the trailer, I lifted each wheel over an ordinary bathroom scale. There will be a small error(2-3%) if the opposite wheel is not raised by the same height to keep the trailer level. The sum of these two weights plus the tongue weight is the total trailer weight. The weight on each wheel was well within the capacity of the scale.
The final total weight of the empty trailer is 510 lb. The weight minus the tongue is 410 lb. Since nearly 60 lb are the wheels, this means the weight supported by the axle is only 350 lb. I can haul plenty of stuff without exceeding the axle rating (800 lb). I am concerned that I should have derated the axle even more. I suspect this axle is still a bit too stiff for the weight of my cabin.
If you have ever noticed an empty boat trailer bouncing down the road behind its tow vehicle, that is what is to be avoided.
A major benefit of low weight is the ease of setting up a camp site. Either my wife or I can lift the tongue and maneuver the trailer as needed by hand to the optimal parking location.
Our current vehicle is a 2011 Toyota Sienna with a towing capacity of 1500 lb. On our first few trips I was very apprehensive as we drove faster and thus avoided interstates. In time, fears were overcome and I discovered that the trailer tows nicely at speeds over 70 MPH. On our trip to the Grand Tetons in late summer 2022, we got over 18 MPG (about 10% reduction). We had no trouble passing slower vehicles over 9,000' mountain passes. I am feeling confidant that when we downsize to a new vehicle we will have many choices in models that will be able to tow such a light trailer.
Getting ready for this trip, I discovered another feature about the Dexter axle. I have repacked many a bicycle hub with grease. Lubing the trailer hubs was much easier. No dissembling needed. You just squirt some grease into the grease fitting. That alone already justified much of the extra cost of the chassis.
I am noticing some damage to the fender paint job from road grit and pebbles. I am happy with my choice of "jeep" style fenders. The flat surface comes in handy when you least expect it. After a three day journey from Iowa, when we rolled into our camp site in the Tetons, the license plate fell off. Other than that, this trailer is holding up perfectly.
The canvas-foam composite structure is remarkable. It is really sturdy. However, I hope we don't test a deer impact.
That clearly replaces the frozen turkey at 60mph as a menace.
The temps dropped into the high 20s F some nights in Jackson Hole. This was not unexpected as I had experienced snow there in August. We were very comfortable, surrounded by 2 inches of foam insulation. Each person at rest produces 100 watts of heat. It is a bit shocking to open the door in the morning to feel the temperature difference between inside and out and see ice in the water jugs left on the picnic table.
