Plywood floor finish options for a 5x8 square drop
Thread Summary
Summarized on:
Original Member Title: Flooring options?
A new member building a simple 5x8 square drop asked for practical ways to finish a plywood floor used mainly for sleeping, including linoleum, peel-and-stick tiles, rubber mat, epoxy paint, polyurethane, or leaving it mostly plain. Members suggested simple, removable, and easy-clean options rather than anything elaborate.
  • One member uses a loose piece of indoor/outdoor carpet over the plywood, mainly to protect an air mattress and add a little comfort underfoot. It is not glued down...
More...
MojaveD
Member
Joined
Apr 6, 2026
Posts
16
Location
Arizona USA
New member, I’m building a simple 5x8 square drop and am looking for ideas for finishing the plywood floor — sheet linoleum, peel and stick squares, rubber mat, epoxy paint, etc. Or, just leave it as is with a coat of polyurethane? It’s basically sleeping quarters only, not a show pony. Thanks in advance for any input.
I have a 60" x 80" piece of green indoor/outdoor carpet in mine. Keeps the air mattress from contacting the plywood floor, and offers a tiny bit of comfort to the bare feet.
Roger
We used a product like this, can trim it to a perfect fit, tons of color options, comfy on knees, feet, adds a bit of insulation, Is cheap, easy to clean, water proof.
2 layers of polar seal 1 layer of closed cell foam and then rubber backed very short nap carpeting. We even winter camp and having waterproofing then insulation and an attractive floor treatment that can be removed to clean is a very very good thing.
Don't use the adhesive backed tiles without gluing them down like you would for non-adhesive backed. Heat of day and in storage will allow the tiles to buckle and lift otherwise. I stained and sealed my floor, but probably was overkill, since it will all be covered by the mattress and bedding anyway.
