Pop-Up Trailer Standy Foamie Conversion
Thread Summary
Summarized on:
Original Member Title: My Pop-Up Trailer Standy Conversion
An RVer documents the detailed process of converting a 1996 Dutchmen pop-up trailer into a custom foamie standy, sharing each phase from demolition to winter storage. The project began with a thorough teardown, salvaging reusable parts and prepping the frame with rust removal, painting, and professional welding for new supports and a grey-water tank. The member emphasizes the importance of planning, research, and adapting to unexpected challenges, such as weather delays and learning the best...
More...
daveo132000
Member
Joined
Jul 27, 2025
Posts
22
Location
Fredericton
Hello all,
I posted to the Newbie form where I discussed embarking on a ‘foamie standy’ build. Due to our weather and my work schedule, I won’t see much progress in the winter months, since I need the garage for our cars.
Since I’ve learned lots from reading about others’ projects, I thought I’d document mine here as well, starting with the demo since everyone loves doing that. ;)
Part 1 (Demolition) begins:
In late October 2024, I purchased a 1996 Dutchmen pop up trailer (model 1001) for $800. It was in pretty rough shape, but with new safety chains and re-lubed bearings, it passed inspection, and it was then brought back home where I had 3 days to cover it with a tarp before the first snowfall. It sat till the May 2025 long weekend when I opened it fully for the first time. No critters, but there was a 'je ne sais quois' in the air from being closed up for years.
I began a notebook where I kept all my info, including existing measurements of the original dimensions for later reference. As I found parts, I wrote their specs and sizes there as well, making it easier to plan out the design.
I quickly learned that a pop up trailer is basically held together by staples and a thousand Robertson square drive screws. A drill, knife, hammer and pry bar made short work of the insides within 6 hours. I scraped the roof’s interior Styrofoam layer from the fiberglass roof, bagging up all the debris, then moved the shell into the garage so the rest could be done in dry (and warmer) conditions.
The roof was cut into strips and then panels with a reciprocating saw, then all the wall panels were cut down to fit into our utility trailer for a trip to the landfill. The floor sheeting was cut into chunks with a circular saw and pried off with a crowbar since it was well glued and screwed to the frame. I salvaged the plastic wheel wells, and tackled the underframe prep.
The lifting mechanism mounts needed to be unscrewed, and some creative grinder work was able to cut the cables and springs so I could have manageable sizes of scrap metal. The old copper gas pipes, bushings, original steps, 12V lights and wiring was held on with a ton of self tapping screws that were all removed or ground flat.
At this point, I decided a couple of runs to the landfill were needed. A load of wood debris, a load of nasty cushions, tent walls, and miscellaneous debris made the yard look presentable again. I kept all the scrapped metal for now, since I didn’t know if it could be useful later in the build.
This ends part 1. Stay tuned for Part 2!
Impressive amount of de-construction! You are well on your way to a really neat framework for a build. Having owned several pop-ups, you are so right in describing their construction. It will be a challenge but it seems you are up for it! Please keep us posted. Most of what you see with these are remakes and rebuilds using quite a lot of the original pieces. This is like a fresh build with a ready-made frame. Well done on getting it to that point!
Part 2 (Frame Preparation) begins:
Mother nature rained every weekend from March through May, then decided to stop in June. At this point in the build process, I needed to do dirty work outside, crawling around under the frame so I was happy to get some dry weather.
I rolled the frame back outside, then spent several hours using a wire grinding wheel on the frame to remove the scale and heavy rust, following up with a smaller drill wire brush for smaller spots. I needed to grind off two original flip-down front support legs that were beyond repair, but could re-use two rear support legs. I rinsed off the loose dust and paint, and allowed things to dry to check for any last spots to grind.
I then liberally applied a TSP spray over the whole frame and followed up with a pressure washer to remove any grease, rust or debris to prepare for painting. It was now late June, so things dried quickly, but I left the frame inside for a week to ensure it was ready for paint.
I purchased three cans of automotive rust reformer spray paint and a spray can plastic handle at Canadian Tire, and essentially sprayed the entire frame then let it dry for a week. Next, I brushed and rolled on about a litre of Tremclad black rust paint on all frame surfaces. Once the trailer is built, I definitely won’t be crawling underneath to paint!
After a ton of research Googling though June, I finally ordered a grey-water tank that would fit under the trailer, as close as possible to the axle for weight distribution, yet give ground clearance and room for the drain piping. Again, Canadian Tire came to the rescue. They sell a special-order Icon Holding Tank with 3” End Drain and tank sensors that fit. I ordered it in July, and work took a pause as we went on a vacation.
While I waited for the grey tank delivery, I tackled the lift jack which scraped and squealed like nails on a blackboard. I drilled out the original handle rivet and removed the mechanism. New rubber washers, wire brushing and Tremclad spray paint followed, then a liberal amount of grease. A short bolt and lock nut replaced the rivet, and now the lift jack now moves like it did from the factory.
The grey tank arrived, so I was ready to get it mounted, which would require fabricating supports. I briefly toyed with the idea of learning welding, and quickly decided I needed a professional to do the modifications I needed on the frame: 1) moving an existing angle iron support to the centreline of the trailer to support floor decking, 2) attaching two new flip-down front support legs, 3) adding removeable brackets for the grey-water tank (so if I ever need to replace the tank I could remove it from under the trailer), 4) adding a spare tire mount on the tongue, 5) adding some diamond plate to fill the gap in front of what will become the trailer’s rear door opening, and 6) fabricating a removeable step from scratch to enter the trailer.
I found a welder 10 km from home that was able to do the modifications I needed, however, a bare trailer frame isn’t road legal! So, I crafted some temporary platforms out of some salvaged plywood from the original bed slide outs and mounted the original wheel wells. I simply zip tied the platforms to the frame. I used a new trailer wiring harness I had to connect up the original tail lights, tested them, and then mounted them on wood blocks and zip tied them to the trailer frame as well. I figured with working lights and wheel covers, my trailer was now better than most of the trailers I drive behind, so off to the welder I went.
Two weeks later, I returned home with a lighter wallet, and a newly modified trailer frame. Definitely worth the money, as the welder thought of ways to do the work I didn’t consider. The grey tank was supported by 2 U-shaped flat supports that bolt up through the plastic flange and into nuts welded onto new angle iron supports stretching from left to right. I supplied him a U-shaped bolt-on spare tire carrier that he cut apart and welded the threaded rods vertically on new angle iron on the tongue, which is a better idea than bolting on the frame side. I was impressed with the removeable step, in that it doesn’t flex or rotate, and simply drops on to the rear bumper for when the trailer is parked.
I did some light wire brushing where the welding occurred, then primed and painted the new steel and welded areas. I then moved the trailer frame into the garage, and removed the tires so I could begin the building process indoors.
I think its important for new builders like myself to realize that planning and researching takes a lot of time, particularly as you try to find parts that will work in a non-standard application, or in a custom build. You need to consider how one part will impact on another, etc.
Just deciding on the grey-water tank took a few weeks as I searched the internet for appropriate suppliers, tank sizes that would fit, figured out how the drain could be routed, how the tank could be vented, and how the fixture drains would be plumbed to the tank. Thank goodness I found a welder who took my sketches and was able to create a solution to both hold the tank and allow the wide support bands to be unscrewed from underneath using bolts. It was well worth the money I paid.
This ends part 2. Stay tuned for Part 3!
Part 3 (Floor) begins:
Finally, new work could begin! I purchased three sheets of ¾” tongue & groove plywood for the floor and began laying them out on the frame starting on the passenger side. The groove edge was run down the (now fully supported) centreline angle iron, and I routered out a notch on the short end to allow an overlap with the next piece. I weighted down this half, and clamped it into place. I placed the driver side plywood next tapping tongue into groove, and staggered the joints to landing them all on frame steel. Once I was happy with the placement, I cut some 2x2 scraps and attached them under the wood, butting them up against the steel frame, around all sides to act as placement guides since I needed to remove the plywood to paint.
I traced the position of the wheel cutouts, then flipped the plywood pieces. I wanted to leave a consistent two-inch overhang around the frame to allow my PMF to glue later in the process, but since things were shifting a lot, I decided to trim the plywood only after it was secured to the frame. I cut out the notches for the wheel wells, planning to later attach the original wheel wells from the underside.
Once flipped, I taped off what would be later the exposed underside for gluing, and applied a primer coat. I followed this with a heavy coat of outdoor porch paint, and removed the tape while wet.
After thoroughly drying, I applied construction adhesive to the frame members, and placed the plywood panels, starting in the rear on the passenger side. The 2x2 blocks worked well to keep things aligned, so I used some self-drilling screws to attach it. I glued the notch, attached the front piece, then glued the entire groove and attached the next pieces on the driver’s side, tapping in the wood till the 2x2s contacted the frame. This left a slight groove down the centreline of the wood I will need to fill later. I then drilled holes for 5/16 diameter 1-3/4” carriage bolts I found at the Habitat ReStore, and bolted each piece of plywood with at least 3 bolts each. I loaded the surface with heavy weight and left it to dry.
Once the adhesive dried, I traced out the final outer edges of the floor. I discovered my frame wasn’t perfectly square, so I did my best getting the walls to be parallel and square to the front, but the best I could get was 3/8” out of square. After multiple attempts, I decided this was within my “acceptable” margin of error, so I trimmed the rear and long edges to their final dimension.
The front of the trailer will be a wedge, with a 2-foot-wide piece of foam extending up at a 45-degree angle, so I trimmed the leading edge of the plywood to length at the same angle. I ripped a 45-degree notch out of the foam on my table saw. Here is where my first mistake occurred. I ripped a 2x4 with a 45-degree notch to be able to lock the foam board down to the plywood, however I ended up gluing and screwing the board to the plywood flush to the edge. By the time I realized this error, it was impossible to remove, so I ripped a 2x3 with a 45-degree notch, and now this board will lock the foam board onto the top of the 2x4. The PMF will eventually get glued to bare wood equal to 2” plywood plus the diagonal of the 2x4. Oh well, it will add more wind resistance strength.
I then marked out the rear shower area and kitchen cabinet placement with tape so I could determine where my used RV entry door would need to be positioned. I was thrilled to find out the measurements I provided to the welder worked out, and my temporary step lined up well to the door opening.
I then built a 2x3 frame for the used RV door, with a temporary bottom member to keep it square, that will be inset into the rear wall. I wanted to have a sturdy frame to support the door, which I expect will see lots of hard use.
I've reached the forum posing max, so this ends part 3. Stay tuned for Part 4!
Part 4 (Foam Walls) begins:
After having watched a number of videos on foamie builds, I previously purchased a 16 oz bottle of Foam Fusion, which seemed to be the best rated glue to join foam. I took a trip to Home Depot to purchase 1-1/2 thick 4x8 sheets of wall foam, and began to join them up. I cut some strips of plastic vapour barrier I had in the shed, and laid them out on the trailer floor so the newly glued foam wouldn’t stick.
I needed to leave for a work trip for a few days, so I worked late the night before to glue the foam sheets to give them time to dry while I was away. Here is mistake number 2, although it really wasn’t clear before I started. Foam Fusion needs air to cure properly. I applied the glue to the notched edges of the foam sheets with a small brush, and taped the edges to keep them in place while drying. Three full sheets to a side and two for the rear wall were glued and laid out on the frame, with weights added to keep things in place. When I returned, I discovered the glue was still wet, so I propped each wall section vertically around the garage to let air reach both sides of the seams. Finally, after 2 more days, I felt comfortable calling them glued.
Wall construction could now begin. First off, I need to be able to get the thing out of the garage. With the wheels off, I could use furniture moving carts to move it, so using the current floor height, my garage door height, the RV door height, and my height, I settled on a 78” wall height. This will allow me to stand up straight with enough space to not feel closed in, and allow roof rafters with exterior foam to be applied while still in the garage. My first attempt at cutting the foam to height with a hot foam knife was a dismal failure so I decided the circular saw was the tool to use as it maintained a clean straight line.
I made two temporary supports, screwing them to the floor, and lifted the driver’s side wall in place. New discovery! My trailer floor isn’t level from front to back along the edge. Grr. So, I needed to scribe the bottom edge of the panels to the wood floor, then trim the excess with a knife and a sanding block. Once the wall bottom made good contact with the plywood over the entire length, I proceeded to build a 2x2 reinforcement to which my wheel wells will later be attached to the walls. I marked out where the wheel well blocking would be inserted, and glued it in with PL300. I repeated this entire process with the passenger side wall.
I cut out and inserted the rear door 2x3 frame, gluing it into place with PL300, and lots of tape. It didn’t hold well on one side, so the next morning, I scraped out the glue, widened the gap, re-glued the joint, and used a ratchet strap to keep the pieces joined while curing. Temps were falling at this point, as it was late September, and the glue was taking long to dry.
Rather than rushing things, I decided it was time to pause the project since work was picking up, and more importantly, the boss needed her side of the garage to park her car.
I purchased some furniture wrapping plastic, judiciously stacked the wall panels and RV door onto the trailer, and wrapped it like a burrito to protect the bare wood floor for the winter. I covered it with a piece of vapor barrier and then a tarp, tying it all to the frame with rope. It was moved back outside by mid-October.
Sharp eyes will note that I still need to add on a short piece of foam panel where the leading edge of the angled panel falls at the front of the trailer, but that step will need to wait till construction continues in the spring. I need to get some exact measurements for the windows and interior walls planned out before I know the exact angle I will cut.
Some notes for people cutting this type of foam:
The hot knife works OK, but I found it hard to control the heat so it wouldn’t smoke, and after it did cut, the edges receded from the marked line. The circular saw (or jig saw) works much better. However, as I made multiple cuts, I discovered an issue using the circular saw…. After making long cuts, the blade began to build up residue from the foam plastic, which caused the cuts to become more jagged or rough. I needed to remove the blade and clean it off with paint thinner periodically. While not readily visible, I could feel the difference between the cleaned and gummed up blade.
This brings my construction phase to a winter break. We already have had three snowfalls, and the trailer is buried under 6 inches of snow, so for the next few months I will be working on planning out the exact placement of my (now stockpiled) components: shower pan, 2 windows, a mini-fridge, and kitchenette. Canadian Tire had a good sale with a bonus point offer so I picked up the fridge and two new tires (the old ones were from 2016) in September, and I ordered some other parts like an electric inlet, water inlet, and exhaust vent during Amazon Black Friday sales.
I have also built an Excel spreadsheet to calculate axle and tongue weights, and overall trailer weight, so I can keep to my target of <300 lbs at the hitch. The trailer has a relatively long moment arm from the axle to the rear, so I need to watch the weight of any materials that are placed behind this point.
This ends part 4. Stay tuned for Part 5 (ETA May 2026)
Part 5 (Winter Projects & Spring Revival):
With the burrito-wrapped trailer outside buried under snow, the winter period allowed some more planning. I developed some drawings with LibreCAD that provided accurate dimensions to place everything along the two side walls. This also allowed me to calculate the convertible bench/beds to be built, and do an estimate of the overall weight of the completed trailer. If my math holds, I’m estimating about 1750 pounds gross, with 128 pounds hitch weight, a bit light. My research suggests approximately 10% of the trailer weight should be at the tongue, so I might use some heavier wood on the front half as I continue the build in the spring.
A couple of small projects moved ahead. I constructed my 30A shore power plug end to a 25-foot cord I acquired, and tested its weather tight connection.
I am thinking I will likely add trailer brakes to the trailer, so I bought a trailer brake controller and the required adapter for my vehicle, and installed it. I used lever connectors so when I eventually get to test the controller, I can easily redo the wiring if I got my wiring criss-crossed.
The original plastic trailer wheels must have scuffed the side of the trailer tires some time in the past 20 years, since there were actually 2 thin cracks in the side wall where the plastic cracked. This would have allowed water to enter the trailer cupboards when travelling in the rain. So, I bought 2 cans of black Flex Paste at Canadian Tire and applied a coat across the inside and outside of the wheel well walls. I embedded some nylon screen mesh into the Flex Paste to give it some strength resistance. Overall, this solution worked well, and the repairs are very well bonded to the plastic. Water tight!
My wife and I attended a spring trailer show in town, and we got some ideas for colour schemes, and some other layout or features to tweak in the interior design. Greys and blacks seem popular now!
After the Victoria Day long weekend, things slowed down at work, so I was able to bring the burrito into the garage to begin working on the project again. The tarping and vapour barrier over my plastic wrap protected the bare wood floor perfectly over the winter months, with no water damage. As I unwrapped the pieces, I double checked no critters had decided to gnaw on anything, and am happy to report all was well.
This ends part 5. More updates soon, as construction has continued!
Part 6 (Grey Water Plumbing Layout):
With the start of work, I needed to determine if my rear wall door location would permit the depth pf kitchen counter I needed, which itself needs to hide the drain pipe going into the grey water tank. If the drain location would be too far inboard, now was the time to redo the back wall with a wider passenger side panel.
With the tires still mounted, I dropped the tongue low and crawled under the trailer to estimate the tank location’s measurements. On the top floor surface I marked out the edge of the planned cabinet edges, so that the drain pipe would be near a cabinet wall and not in the centre of the storage space. I drilled a pilot hole in the floor, and dropped down a rod marked with grease pencil till it touched the tank.
I then crawled under again, unbolted the grey water tank (last summer, my welder fabricated support straps held up by 4 bolts accessible under the trailer) and noted where the mark landed.
I previously bought a rubber fitting to insert into the tank that will accept a 1-1/2” ABS pipe (Icon Direct Holding Tank Fitting 1 1/2" Rubber Grommet SKU:12483), so I measured how far I could move the centre of the drain hole towards the outer edge of the trailer, then re-installed the tank.
From above, I drilled a new pilot hole through the floor and into the tank. Once again, I removed the tank, and double checked the rubber fitting centred on the pilot hole would seal but be as close as possible to the tank end wall.
I marked out the required hole on the floor, and measured to the passenger side wall to confirm if my rear wall could accommodate the cabinet to hide the pipe. It does, but only barely, and I won’t be able to have a toe kick at that spot, but I’m fine with it.
So, I drilled out a hole in the tank, and inserted the rubber fitting. I then drilled out a hole in the floor, reinstalled the grey water tank for the final time, and cut a stub of pipe to test out the connection. Everything worked well, so I taped over the hole for now to give me a level surface to work on the wall panels.
This ends part 6. Wall panel work is next!
Part 7 (Wall Panel Work):
With the original side walls propped up, I used two cut offs to extend the front of the walls where the trailer’s front 45-degree shape will extend to. As this glue dried, I did some of the other steps previously posted.
I placed the driver’s side wall panel in place onto the floor, with a temporary brace. Then, I used the lower half of the angled front wall to mark out where the wall panel needed to be cut, and where the top half of the front wall will begin to angle back towards the roof.
I then placed the passenger side wall panel in place onto the floor, with a temporary brace. I again used the lower half of the angled front wall, sliding it flush under the driver’s side angle cut to then allow me to mark out where the passenger side wall panel needed to be cut, and where the top half of the front wall will begin to angle back to the roof. The lower half of the angled front wall is still wider than the trailer, so I can cut the final width once the wall panel placement is permanent.
I then laid the passenger side wall panel on the floor, and used a string line to so that the angle of the top portion of the front wall would be 90 degrees at the tip, and meet the roof at 45 degrees. Once laid out, I snapped a chalk line, and cut the panel to shape with a circular saw.
On this wall panel, I then marked out the various items that needed to land against it, such as a length of top cabinets, the mid-cabin shear wall, lower kitchen cabinets, a convertible seat/bunk and finally the egress window. All items fit according to my CAD plan! These marked lines will eventually be covered by an interior panel skin, but this step permits me to lay out the plywood inserts I will need to make next.
With passenger side wall panel cut and marked up, I used it as a template for the driver’s side wall panel, and also cut the front wall angles. I flipped it and also marked out the various items that needed to land against this wall.
This ends part 7. Wall panel inserts are next!
Part 8 (Wall Panel Exterior Light Inserts):
With the wall panels cut to size, I planned out where my exterior lights needed to be placed for the trailer to be road legal. Princess Auto had LED tail lights and red and amber marker lights on sale a while back, so I purchased a complete set. They are all surface mounted, so I decided I wanted a bit of meat to screw into after the exterior skin was in place.
I found a 2’x2’ ¼” birch plywood panel at Home Depot, and cut the various inserts needed for the lights.
I did a test plunge of my router with a rabbiting bit to measure the cut to the edge of the base, which then allowed me to measure and tape on temporary stop blocks to guide the cuts. Then I set my depth, attached a vacuum, and cut out the various clearance light holes.
On the rear wall panel, I marked out for the tail lights and license plate, as well as the top and centre marker lights and an exterior door light. With the stop blocks in place, it went fairly well. Any round corners were simply trimmed square with a razor knife.
I spread a thin coat of PL Premium onto each of the wood inserts, and adhered them into the wall panels till dry. A bit of sanding might be needed to ensure they are plush to the foam surface before I skin the outside.
This work was quite exacting, and took a few evenings to measure out and cut the holes. I definitely needed the vacuum to remove the foam router shavings…. With ear defenders on, I once forgot to turn on the Shop Vac and immediately the foam bits blocked my view and clogged up the cutting area!
This ends part 8. Wall panel Interior inserts are next!
Part 9 (Wall Panel Interior Inserts and Rebuilding the rear wall panel):
On the inside surfaces of the wall panels, I marked out where the small closet, walls, benches, base cabinet and overhead cabinets will land and used tape to make it clear for visualization.
I had saved some of the original trailer’s aluminum rails, which ended up being good straight edges to guide the router. I cut 2” grooves to accept ¼” plywood strips to act as reinforcement when the interior components later get attached to the walls.
After all of the grooves were cut, I re-measured the actual size of the wood required. I bought a 2’x4’ piece of the same plywood as before, and cut strips slightly wider than 2”, to fit into the grooves. Where needed, a slight trim with a razor knife made a nice tight joint. Learning from my marker light inserts, I routered a little deeper this time to allow room for the adhesive too.
Next, I laid the panels out, spread a thin coat of PL Premium onto each of the wood strips, then adhered the strips into the wall panels till dry. Overall, this whole process took 4 evenings to complete.
I then did a test fit of my rear wall panel onto the trailer floor, and discovered somewhere along the way last fall I had messed up the measurements. The panel is meant to fit between the side walls but it was wider by 1.5” and also didn’t line up with my step. I needed to cut 4” off the driver’s side, and extend the passenger side by a few inches. So, I ended up sawing along the glue bond next to the door frame, then buying a new 2’x8’ foam panel and cut it to 80” high to fit in the car to get it home.
I scraped off any remaining glue from the wood, then adhered the new panel to the side of the door frame with PL Premium and let it dry. The next day I cut new grooves into the panel to extend the marker light and tail light plywood to their new positions, then glued in new wood inserts, and let things dry for the weekend.
This ends part 9. Floor blocking and interior panels are next!
Part 10 (Floor blocking and interior panel surfaces):
With the three wall panels ready, I test fit the sides and rear onto the trailer base, flush to the outside edges. I used some strapping and attached some 2x2 blocks to one end to use as wall-top braces. I then added some vertical braces to check for plumb, then once both walls were vertical, I added the other 2x2 blocks to the other side of the strapping to restrain movement in or out. I did the same thing to hold the rear wall, using strapping at a 45-degree angle from each side wall to the rear wall.
Once I was comfortable with the wall placement, I vacuumed the floor, and cut 2x3s to act as bottom of wall gluing surfaces, following the recommendation of GHOCE (many thanks!) to attach walls that I gleaned from the TNTT forum.
On the rear corner of the driver’s side, I used 2x4s because of the height of the shower pan. These were cut down on my table saw to 1-1/4” thick so that later I could add 1-1/4” vinyl siding drip cap to cover the surface from the shower wall into the shower pan that I had purchased from IconDirect.ca (Shower Pan SP600). The lumber was glued with PL Premium, and screwed from underneath the trailer floor close to the frame. (The plywood overhangs the frame by 2”).
I next began work on the interior walls’ finish surface, which is ¼” meranti plywood, normally used as underlayment. Eight sheets covered the side and rear walls, with any horizontal joints planned to fall below the counter and any vertical joints behind the shear wall or cabinet.
I laid out the panels, cutting them to fit to the foam panel dimensions, keeping them back from the edges 1/8” to allow for “fudging” the foam joint later through sanding. At the rear wall, I needed to allow for the 1.5” foam thickness. The plywood was cut to stop above the floor 2x3s. I weighted down the cut pieces as I measured and cut the next pieces to ensure the measurements remained true.
In researching adhesives, I wanted to use something that would be ensure good contact across the entire surface, not use a bead of adhesive that would leave large areas unglued. I discovered GluDown Foam Board Adhesive which had a local distributor, so I chose to use it, and ordered 12 spray cans.
I began by preparing the foam surfaces for gluing each time by first sanding with 120 grit sandpaper then vacuuming up any dust. The adhesive works like contact cement, in that you spray it to both the foam and plywood surfaces, let it flash for 3+ minutes, and press it into contact. It doesn’t glue wood to wood, so where I have the plywood surfaces, I applied PL Premium.
Once I sprayed the adhesive onto the two surfaces and it flashed, I laid out some ½” dowels across the foam surface, then carefully placed the panels into place. It sticks very quickly and ‘aggressively’! With the first panel, I took time to mask off overspray with newspaper, but as I gained experience, I just used a piece of cardboard to avoid overspray. Each full wall panel was glued and weighted down for 24 hours before being moved. 8.5 cans were used for the three wall panels (one can didn’t spray properly), so I should have enough to finish the front panel when I make up that panel.
Overall, the cutting and gluing the plywood to the three foam panels took 5 evenings of work. This ends part 10. Side wall panel placement is planned next!
Part 11 (Side wall panel placement):
With the wall panels ready for installation, I had a buddy to come over to assist with the assembly steps, since they were too heavy to move by one person.
We first test fit the panels into place individually to ensure the inside plywood didn’t impact the base 2x3s along the floor. No issues, so I applied 3 beads of PL Premium to the 2x3 surfaces, and 2 beads to the floor plywood, again using GHOCE’s method of attaching foam to his base in a video I watched (many thanks!).
After placing the first wall panel, it needed to be braced to prevent movement while the glue cured, so I first screwed a piece of strapping through the foam wall to the inside 2x3 using 3-inch screws. This ensured that the foam stayed tight to the wood surface on the inside, and also pulled it in to ensure the floor’s edge was flush to the foam wall. With each panel weighing at least 40 pounds, I didn’t see the need to use any ratchet straps to keep the panels tight to the floor surface like in GHOCE’s videos. Later, I’ll simply fill these few holes with glue or foam before skinning the outside.
Once the floor joint was secured, we reinstalled the vertical braces I used previously, after adjusting for the added plywood. We repeated the process for the second side wall, then moved to the rear wall.
For the rear wall, we tilted in the bottom edge first, keeping the side panels tipped out slightly to avoid pushing out any of the 2 beads of PL Premium laid vertically on the side panels. After securing the floor joint with adhesive and the outside strapping as before, we plumbed the wall vertically, and used bamboo skewers (another forum lesson learned!) every few inches to align the corners. With the walls plumb, we used tape to keep the joints tight.
In addition to the vertical braces, I then reinstalled the roof braces, adjusting the stop blocks for the added interior plywood.
This step was a milestone in the build, a point of no return with final assembly of 3 walls. I plan to allow the glue to cure for several days prior to putting any stress on the joints. With these walls in place, I will be able to work on determining the final dimensions for the front wall panels and the roof panels.
This ends part 11. Front wall panel construction is planned next!
Part 12 (Front wall panel construction):
With the side walls solidly placed, I started construction of the lower front wall panel. A test fit of the foam revealed the side walls were not parallel, so I moved the strapping braces to the front, confirmed my walls were parallel, then marked the final dimensions for the foam, and traced onto it the limits of the plywood to be cut and adhered as a panel.
I wanted to save the remaining GluDown adhesive for the larger top front panel, so I used nearly a tube of PL Premium, spread it as a thin coat over the foam surface, laid on the plywood, and weighted it down well till it cured. I definitely preferred the spray adhesive, as I found the plywood slid around as I lined up the edges.
After two days, I enlisted the boss’ help to place the lower front wall panel. 2 beads of PL Premium on each surface of the floor’s wood notch were laid down, then I used triangle braces, bamboo skewers and plenty of painter’s tape to hold things in place till it cured.
With the trailer level reconfirmed, I began to determine what adjustments needed to be made on the wall panels. The driver’s side front angle needed to be shaved down to meet the lower front wall panel properly. A bit of plywood needed cutting, so I used an oscillating saw. The rest was sanded with a drywall sanding block, and confirmed true with a 4-foot level.
I then attached a self-leveling laser to the side wall and shot a level line on 3 sides. I marked pencil ticks on the walls around the outside, then used a 4-foot level to draw a level reference pencil line around the perimeter, extending it to where I wasn’t able to shine the laser.
With a reference line established, I measured from it to the top of the wall panels at multiple points around the perimeter. From this, I was able to establish my lowest point, so then I marked out how much foam or plywood needed to be trimmed at each point, and re-drew a line connecting those points to make a true, level roof surface.
Once this was complete, I finished an easy task, drilling or cutting from the outside in, the three openings for the water and power inlets using hole saws or the oscillating saw. Test fits of the plastic inlets were confirmed.
This ends part 12. Wall panel levelling and roof joists are next!
Part 13 (Wall panel levelling and roof joists):
With my new reference line to mark a true, level roof, I trimmed foam and a bit of plywood around the perimeter of the three walls as necessary, then sanded till smooth. The largest trim cut was ¼”, with other points needing only a bit of sanding.
I then ripped a 45-degree angle along a 2x3 to add support where the front top wall panel meets the roof panel. Using this joist, I used the oscillating saw to cut a corresponding notch into both walls to drop it in. I first moved a strapping brace to ensure my walls were at the correct spacing, then used PL premium and tape to secure the joint.
My interior shear wall (that ends the sink cabinet, hides plumbing vents and encloses the fridge/closet) was laid out, tight to the wheel wells according to my plans. Using the self-leveling laser, I shot a plumb line onto each wall, then marked it with pencil. This allowed me to locate then add another 2x3 joist across the trailer width, again notched into the wall panels, and over my vertical plywood inset. After gluing and taping these joints, I added a vertical 2x3 under it to each wall, gluing them at the top and bottom and using screws to connect it to the joist and floor rails. I also added 2 beads of PL Premium to adhere the verticals to the wall panels, then after applying a temporary brace on the outside surface, I screwed 3” screws through the foam to true the wall and allow the adhesive to bond well.
With the shear wall location known, I extended it along the floor to find where the walls will extend into the aisle between the fridge and sink cabinet. From this I was able to determine the centreline of the aisle, which I transferred up to the 2x3 joist.
Moving rearward, my next joist needed to accommodate a ceiling vent hole, so I added one 14” from the 2x3. I centered the opening on the aisle centreline, gluing and screwing side blocks 14” apart. At this point, I’m still unsure if I will install a vent so as to avoid leaks, but I’m framing for it regardless.
From there, I decided on two more 2x2 ceiling joists, at 15” spacing, with a final third joist flush to the rear wall to act as a ceiling nailing edge and to help keep the rear wall true. I marked the positions out and cut wall notches as before.
I then cut the remaining ceiling joists to length, and glued and taped them into their notches. Along the rear wall, I added a horizontal bead of adhesive and clamped it midway to the wall to ensure a good bond.
I then cut, glued and screwed three 2x2 blocks to connect the front 2x3 joist to the shear wall 2x3 joist, then added 2x2 blocks between the remaining joists down the centreline of the trailer to the rear wall. Later in the project, wall-top shelves and the closet/shower wall will be attached to these joists adding bracing, so there is no real need to add more blocking inside the roof itself.
Next, I then used a strip of painter’s tape to make a series of vertical measurements, working from the roof down to identify where the ceiling, wall-top shelf bottom, frame, and underside, wall gap, window hole, wall gap, rear seat cushion, and seat surface would land. The windows came with a cardboard template so I traced it out onto the two wall surfaces, keeping the holes edge 3” from the shear wall. As planned, the wall-top shelf frame will land nicely over the inset plywood buried in the foam, allowing screws to be used.
Before cleaning up, I finished up by drilling some 3/8” holes through the ceiling joists near the walls, and through the blocking to the centreline of the aisle to permit running 12V wiring later on for exterior and interior lighting.
This ends part 13. Front and roof panels are planned next!
Part 14 (Roof panel):
Originally, I was going to form the sloped front wall like the other walls, but with the wind force moving down the road, I decided to make a composite panel. I cut and glued horizontal 2x2s into the sloped front wall, letting the adhesive set overnight. I then cut vertical pieces, glued and screwed them to form a grid, lining them up with the roof joists.
Over the winter I had originally planned to taper 2x3’s with a table saw to form the flat roof joists, but I didn’t have a great way to ensure they would have a uniform surface, and then couldn’t figure out how to manage the angle change from that to where the flat portion meets the angled front wall.
I had kept one of the original roof joists from the pop-up trailer, and measured that it dropped ½” over 41 inches to each side. This is fairly slight, so I decided to create at least the same taper by using cedar shims, and some of the cut-offs from the wall panelling. Stacked and spaced, it matched well.
So, I stacked plywood and shims on each of the roof joists on the flat roof, glued them and shot staples through to keep things in place. On the roof plane towards the front wall or rear walls, I sloped the shims towards those walls. After joining two more foam sheets to form the roof, I cut a few kerfs across the roof panel to allow this flex a bit better.
I then transferred measurements to the roof panel to insert plywood to permit screwing down a square vent and a stink pipe cap. I routered the foam, spread a layer of PL Premium, and weighed down the inserts for a day.
While the glue dried, I needed to wait for a day till a buddy could come over to help place the roof panel. I framed in the 2x3 shear wall to help support the roof, and did some more planning of the next interior parts.
My buddy and I then lifted the oversize roof panel onto the roof, marked out the wall edges with a bit of extra to be sanded flush later, then moved it down to cut it to size. Then we lifted it into place, and while being propped up, I spread a generous amount of PL Premium across all roof joists and the roof edges. We dropped the roof panel into place, verified the placement, then weighted it down with bags of salt and fertilizer for two days till everything cured. With the weight, the foam panel's flexibility allowed it to conform to the roof slopes.
This ends part 14. Front panel is planned next!
Part 15 (Front wall panel):
The front wall panel was made using 2” thick foam panels (everything else used 1.5” foam). I originally was going to use these for the flat roof, but decided highway wind forces would be more in transit, so I reserved them till now. I cut a 45-degree angle down one foam panel to meet the flat roof plane, then placed it onto the trailer so I could mark out the width and where the front marker lights would be placed.
I then routered out the final two plywood inserts for clearance lights, glued and weighted them down as usual. I sanded both sides of the two foam panels now since it would be impossible later. The next day I spread PL Premium on the wall edges and 2x2 joists, then set the top panel into place, using bamboo skewers and tape to hold things in place.
I then placed the lower panel, traced the wall positions to allow it to be trimmed to size, then adhered it to the trailer as before. The last one, yay! I laid a large wood panel onto the front wall to help weigh it down over the 2x2s while the adhesive cured.
Once the adhesive cured, I used the off cuts from the various foam panels I’ve kept tucked away to make insert panels. I simply cut them with a knife to fit within each of the front wall’s grid spaces.
Then, using GluDown spray adhesive I bonded them to the underside of the front wall. After this, I used some low-expansion expanding foam to fill in the gaps around the insert panels to make the front wall a solid diaphragm.
Next, I taped the cut lines for the windows to minimize chipping and used a jigsaw with a fine blade to cut openings in both walls for the windows. I sanded the openings, then test fit the windows to confirm their flanges covered any inaccuracies in my cuts.
Finally, I drilled a pilot hole through the centre of my stink pipe plywood insert, then drilled up from the inside to permit my ABS vent pipe to exit unimpeded. I test fit the pipe cap and confirmed all the needed screws would bite into plywood.
This ends part 15. More inside work is planned next!
Part 16 (Inside work continues):
I trimmed flush all the expanding foam on the front wall, then measured the lower panel size. I cut down a sheet of meranti to fit on the lower half, sprayed GluDown Adhesive on the foam and spread beads of PL Premium on the wood joists. After placing the panel, I shot some brads to hold it, and added a few braces.
Before I could add the top panel, I needed to send a pair of wires from the front clearance lights inside into the trailer. I drilled in at an upward angle, then routed the wires above where the wood panel will reach the ceiling.
This then allowed me to cut the top panel to size, and place it like the lower sheet, ensuring the centre joints were factory edge to factory edge for a clean joint. More brads and temporary braces were added till the adhesives dried.
I then cut the large shear wall plywood to size, gluing and brad nailing it to the inside wall that will enclose the closet.
I picked up some nice 1x2s (which match the foam thickness) at Home Depot, and worked on the 2 windows to inset some lengths on the 4 sides of each window to add some rigidity, even though my windows will actually squeeze together and don’t require surface mount screws. I first clamped a straight edge along the required cut lines, then used an oscillating saw to repeatedly push through the foam till it touched the inside plywood. After prying out the bonded foam, I sanded it smooth, then glued in the 1x2 lengths with PL Premium, clamping and taping the wood lengths till they cured.
I then worked on the other clearance light wires around the top of the trailer, drilling in from the outside locations into the ceiling space. After some creative fishing, I passed through a pair of wires at each spot, and connected them up around the perimeter, to eventually drop one pair down the shear wall to eventually connect with the other trailer lights. I connected a 12V power source and tested that I had solid connections throughout.
The final step before being able to finish the ceiling was to run 12V wire feeds to my various light and fan locations, stringing the wire from switch locations to where the distribution panel will be placed. The outdoor porch light needed to have a small channel dug into the foam to pass the wires from inside to the mounting panel, but this later will be filled with expanding foam when I finish the outside surface preparations.
All in all, I didn’t get as much work done as I wanted, as I was sick for a number of days, but thankfully that has passed and work has continued.
This ends part 16. Final exterior cutouts are planned next!
Part 17 (Final exterior cutouts):
I next cut out two storage door holes on the lower walls, in the same way as I cut the windows, just above the 2x3s securing the wall panels to the floor. These will allow me access for an air conditioner vent on the passenger side and the drivers side for cargo or battery storage. I did a quick test of my salvaged storage doors to confirm the openings were OK.
I then cut notches and 1x2s for the 4 edges and glued them into place to provide somewhere for the mounting screws to bite. Each opening’s 1x2s cured for 24 hours before the clamps were removed.
After measuring out my upper cabinet position inside, I determined where a passenger wall vent will exit, drilled through 4 small pilot holes, then marked out on the outside where to inset plywood. Then, with a vacuum hose extension, I routered out foam to then glue in an insert. I screwed through the eventual hole into a block on the inside to apply pressure as it cured.
I then determined where my driver side Maxxair dome fan will be placed, drilled a centre hole, and then routered out a circle then glued in a plywood panel, again screwing it to a block inside to provide pressure as it cured
While all these wood inserts were curing, I cut out additional foam panels to insert into the ceiling spaces between the joists. I placed a temporary wall down the centre of the trailer to ensure the roof plane was true, then used GluDown Adhesive to bond the insert panels to the roof panel. I then spray foamed the gaps, leaving gaps where the wires running along the joists in case I need to even change them. I later trimmed the excess foam flush to the ceiling joists.
This ends part 17. Exterior prep is planned next!
Part 18 (Exterior prep):
To do all of the exterior work, I needed to move the trailer to one side to give more space to work, so I did so with four furniture moving carts, jacking the front down then up to land the frame rails onto the carts. Then I returned the frame back to its wood blocks and re-leveled it.
After adhering the roof panel edges a few weeks ago, I noticed that I should have tapered the roof joists all the way to the ends of the joists as the roof flattened out. I thought I might experience water pooling at the edges, so I used a power planer to actually shave down the roof panel edges a bit more. Two to three passes around the perimeter worked surprisingly well, which I followed up with a good sanding to remove any lines. I confirmed with a 4 foot level that the taper extended uniformly, and the outer edge was as straight as possible.
I then used my oscillating saw with a wide blade to flush trim the overhanging roof panel edges flush to the wall surfaces. Then I sanded all these edges flush and smooth.
All this planning, cutting and sanding took about three hours. It generally sucked. If anyone does this work, wear a hat and a N95 mask since heavy dust was everywhere! I’ll let this picture say 1000 words:
The next day I took the opportunity to cut a hole for my Maxxair dome fan, then sprayed expanding foam in any remaining exterior joints, let it cure, then trimmed it flush with the oscillating saw. I found doing this step wasn’t as great as I hoped, since after sanding, the foam tended to still project above the wall surface.
After the foam cured, I sanded the remaining exterior wall surfaces that had not yet been sanded yet. Again, a mask was a must. The next night, I did a massive clean up in the garage. I put away all the tools, swept out the trailer, moved all my long wood and foam cut offs into it for storage, then vacuumed the floor and other surfaces around the garage. All the small foam cut offs were bagged for garbage pickup. I wanted to have a relatively clean area before I could begin any gluing or painting the exterior.
I purchased canvas drop sheets and washed and dried them at a commercial laundromat with machines large enough to handle the two 12’x15’ drop sheets and three 9’x12’ drop sheets. I lucked out and 4 machines were available at the same time.
That evening, I added some long hose to the ShopVac and I used a brush attachment to clean the exterior dust off really well. After this, I used GHOCE’s process to clean off any remaining dust with rubbing alcohol, using a cloth on a Vileda Bath Mop to reach the surfaces more easily.
Next, I applied DryDex spackling to fill in any gouges, dings, skewer holes and manufacturing marks in the exterior foam. I found using a 1.5” knife to dig out two to three scoops onto a 6” knife was about as much spackle as I could apply before it began getting hard. I used a very flexible 4” plastic knife to actually apply it and scrape off excess around the trailer. I kept a bucket of water and a cloth handy as I applied the spackle, and each time I needed to load up a new quantity I cleaned off all the knives first. Occasionally, I used a spray bottle to mist the applied spackle to allow easier application over long lengths. One 946 ml tub did most of the trailer, but I ran out just as I started the roof.
This ends part 18. More exterior work is planned next!
Part 19 (More exterior work):
After measuring the tip of the front of the trailer body to the ball position, I decided to allow for a 1200 mm tuning radius (outlined in a CSA RV standard) so I didn’t risk hitting the body while turning with a vehicle. This should have been planned earlier, but I overlooked this detail. So, I measured back to the front slope where I needed to cut back to, then cut across with my circular saw. I extended a vertical line down each side, then cut across the bottom slope with a jigsaw. Then, I needed to use a hand saw to cut through the 3.5” of foam and interior plywood to separate the pieces. I can confirm that the foam adhesive worked well, as the I found the best tool to dig down to the plywood to be able to insert the hand saw was a flat prybar and hammer.
After lopping off the trailer’ nose, I extended the embedded framing with 2x2s vertically, filled in the bottom with a 45-degree cut 2x2 and the top with a square 2x2, glueing and screwing everything into place. I then cut a new 1.5” foam panel with two 45-degree edges with my table saw to fit within the opening, and adhered it with PL Premium on all the foam and wood surfaces. I screwed a piece of strapping through the foam into the framing to hold it snug while the glue dried.
I then cut more scrap foam panels down to fit within each stud bay opening on the inside, adhered them to the exterior foam with GluDown adhesive, then used expanding foam to fill all the gaps behind the wood framing and along the foam edge gaps to make a solid diaphragm.
The next day I filled any exterior gaps with expanding foam, trimmed the interior foam flush and cut a plywood panel to fit, adhering it with PL Premium, using brads to hold it in place while curing.
The day after, I trimmed the exterior foam, sanded, then applied DryDex spackling to fill in any dings. I also did another pass around the trailer to apply another coat over areas I previously missed, the roof, and anywhere the joints were not flush.
Following this, I then sanded the spackling smooth, vacuumed the exterior, then wiped it down with a cloth with rubbing alcohol, as before. All of this work was like a final exam, repeating all the steps needed for the whole trailer, except compressed in a small area in a week.
While I was doing the final exterior cleaning, my wife ironed one of the pre-washed drop cloths, then we decided to apply the first piece of PMF to the rear of the trailer. Before beginning, I measured the exact locations for all of the exterior inset plywood pieces where the running lights will be attached, referencing each finished edge, because the inserts won’t be visible after applying the drop cloth exterior.
After much research and reading online, I decided to use the process detailed by “L Wood by Lucy” in her PMF tutorial.
I made up a small T-square with holes at the 1.5-, 2-, 3.5- and 4-inch marks, so that I will have an easy way to run it along the various edges of the trailer to mark lines on the foam and to trim the drop cloth, to ensure I maintain 2 inches of overlap past each foam seam. Then, we began to apply the drop cloth, starting at the top edge, cutting small slits where the exterior light wires exited the trailer. I applied Titebond 2 wood glue without dilution to the foam wall, rolling it on it a foam roller, and using a brush on the edge overlaps and along the bottom. The drop cloth was first smoothed out by hand, then ironed smooth set at 4/7 heat. It was wrapped 2” onto each side and the roof, and 1.5” into the doorframe. Overall, it went well for our first-ever attempt at gluing canvas to foam, with only a small pucker over the door header because we stretched the damp material contrary to guidance!
When we work on the next piece on the side, we won’t use water in the iron, since it dripped out as we ironed sideways across the panel. Having a bucket of water nearby worked well, since we had to clean glue off the bottom of the iron several times as we ironed the edges, and when we were done with the tools, we just tossed the brush and roller into it to allow easy cleanup. Instead of pouring glue directly in the paint roller tray, I used a garbage bag to first line it. While it tended to bunch up as the glue was used, it allowed a very easy clean up, so we’ll do this again.
With this work complete, we’re taking a break from construction for a few weeks, as we head off on a planned vacation trip.
This ends part 19. More PMF is planned next in a few weeks!
