Potty Question
Oldragbaggers
Senior Member
Joined
Aug 1, 2011
Posts
1,842
Does anyone use this Cleanwaste Go Anywhere PETT toilet system?
image.php
We have a traditional marine porta-potty that you have to add the water and chemicals to, but we thought maybe it would be nice to be able to dispense with the whole "dumping" chore. I've read some reviews but I would like to hear from you folks if anyone has one.
What timing, I was just looking at this very same one.
Doesn't look real sturdy but I may try it anyway.
I don't know about that particular brand; but, the two things that I would be careful of with that open type with legs are:
- They are known to develop cracks in the legs so that the legs break at the most inopportune time.
- If a waste bag leaks or breaks, there is nothing to catch the fluids.
If you can get either a luggable loo or make one out of a bucket and potty seat, you might be better off.
If not or if you are buying that style for its compact storing properties, simply check the legs each time you set it up for use.
As far as the bag leaking? I've only had one, two-bag system spring a leak all the way through both bags and I think that one had help from a practical joker.
For ease of use and disposal, I really like the bag system.
I had one in the teardrop and made a base that served as a storage unit and raised it enough to make it more user friendly for old legs.
image.php
image.php
image.php
Sold the teardrop and the Pett now lives in my vintage trailer, it has served me well.
I was having some plumbing work done at home one day and needed to use the facilities. Instead of going to
the neighbors I utilized the Pett inside the trailer... and the TV was right there too. :D
Thanks everyone, for the info.
Sharon, I don't always believe the advertising, but this company claims that this potty holds a 500 pound person. Can that be possible for plastic parts, one wonders?? But even if it holds half that, we will be covered. As far as the broken bags, I guess I could place some other kind of liner in there before placing the disposable bag in it....just in case.
Dennis, one question.....are those legs as hard to open and close as some of the reviews say??
I know nothing is perfect, but we have used the standard marine porta-potty for many, many years, and while they serve the purpose very well (and I already have one....) I have never enjoyed the task of dumping and cleaning them. Yuk. If there is a better option out there, I am definitely interested.
Yes, Becky, the legs should hold up well and probably would hold a 500 pound person or they wouldn't dare say that.
I'm talking about as the plastic ages, not right away. Some plastics will age and deteriorate with time.
Just watch for cracking on the legs; and, if you never see any, you'll be good to "go" for as long as you need to! :roll: :LOL:
Not that I recall but I have had this one for 6 years, newer models may be different.
If you elect to make a booster. storage box be sure to have rails on the top so the Pett does not slide off :shock:
Thanks for that heads up!! :LOL: :LOL: :LOL:
I have often considered the pETT. I really like the foldability. Currently have the reliance one. Is mot real sturdy, but i rarely use it , so i went cheap. Let us know your review, becky if u get it
In a word NO!
I can see a fat man picking plastic shardes out of a tender side of me.
As the king of cheap I simply grabbed a 7 gallon bucket ( handicap height) and screwed on a used (and sanatized) wood seat to a lid I had cut the center out of. I had an additional lid if needed to transport. Double bagged it with the tall kitchen bags trapped them in the lid to bucket seal and you are "GOOD TO GO !"
image.php
P.S. A little saw dust or scented kitty litter is a good addition.
I agree with BobHenry, no matter which one you get add some absorbent/deodorant material to it for use. I like peat moss, but I haven't compared it to anything else.
PS. With either the water or the bag system, you still have to dump the stuff. The difference is that one, you do when it is full and maybe spill a little of the nasty stuff when you dump it. The other, is totally contained, 99.9 percent of the time and you dump it daily, bag and all.
BobHenry, I've perched on one of those home-made buckets. They break, too. Don't ask me how I know.... :oops: Keep an eye open for wear cracks.
(Maybe that's why Droid wants to build a wooden one.)
I bet the one that broke did not have the lid in place at the time. I have load tested to 320 pounds standing on them as a foot stool and never had one buckle or fail with the lid on it. Without the lid yes I have been pitched off.
BobHenry,
After seeing your walker tables, you inspired me to look at my neighborhood thrift store for ideas. I found a "bedside commode" with the push button adjustable legs (that come out for easy packing). It has support arms, Holds up to 350 lbs, adjustable height, works with bags, and all breaks down to fit in a 24" x 24" x 6" bag I made (that also holds my popup). I would never have thought of it without seeing some of your ideas. And the best part.... It cost me $12. :D
I'm sorry to jump in on your conversation but all of you are becoming a part of my life.... even though I mostly read about your adventures.
Cheri
cheri832":3fmc4gh8 said:
BobHenry,
Cheri
BobHenry adds the spice to camping life! :D
(Bob, I didn't get pitched off...the dagnabid thing broke and I went right down into the contents!)
S. Heisley":2jbn79mk said:
cheri832":2jbn79mk said:
BobHenry,
Cheri
Bob always has the common scene answer for almost every situation. I always value his opinion. Because it is usually the right one
I have the pett system. bought it in 2007. When using the td I set it up in my shower tent. when using the Scotty we use it inside.
Very sturdy.
the chemical inside abosorbs up to 8 times its weight in water. EPA approved for dumping.
We really like not having to clean up a bucket or having to dump units that require cleaning.
Larry
we use a 5 gallon bucket with a snap on seat and 3 or so inches of soft wood pellets in it. then we burn the pellets in the fire, no smells other than pine, it works for liquids just fine
New posts
