Preventing Moisture Under a Teardrop Mattress
Thread Summary
Summarized on:
Original Member Title: Mattress Moisture--Newbie question
A new teardrop owner asked how to prevent dampness and mold under the mattress, especially with coastal Northwest travel and prior boat-life moisture experience. Members suggested several approaches, including tipping the mattress up when possible, using Hypervent or Froli for airflow, placing inexpensive kitchen wash-down tiles under the mattress, or adding a 1/2-inch foam sheet as a thermal barrier.
  • Hypervent was described as effective and adding about an inch of height, while Froli...
More...
GreenSkelly
New Member
Joined
Jun 14, 2026
Posts
3
Location
Northern California
Hello!
We got our first teardrop a couple weeks ago and are headed out on our test-trip later this month. Since I used to live on a boat and battled with moisture/mold as expected, I'm curious about how to avoid the underside of the mattress getting damp and gross. We live near the coast and travel along the NW coast quite a bit, so my boat-life is influencing my thought process.
I've seen mess underlayment, shallow plastic grids, and a few other things. The trailer does have a good-sized vent with a fan.
What has worked for you?
Thanks! --Skelly
I use Hypervent under the mattresses in my teardrop and Oliver. It’s very effective. Another good option is the Froli System.
Hypervent adds about an inch to the mattress height. Froli adds several. Both systems get good reviews.
I used regular kitchen wash down tiles. They can be found quite inexpensively. It breathes well, it seems.
In the middle of Idaho and beyond, we've never had a condensation issue, but our floor is insulated, and the mattress is 8" thick.
If you have this problem, you could solve it by adding a piece of 1" polyiso foam board (35$?). Or, if your mattress isn't dreamy*, get a thicker mattress and then see if your forecasted problem is a real issue.
*Holler if you want a link to a great mattress. There's no reason to pull a bed-on-wheels unless it's a superb mattress.
