Project Siesta
Betonhaus
Advanced Member
Joined
Sep 17, 2020
Posts
47
Hello, this is the design i'm currently working on for my tiny trailer, it's designed to hold a double/full sized mattress and my initial estimate is $2,000CAD/$1,600USD for all parts (before shipping and screws and bolts and other fiddly bits) and should weigh about 200lbs or a little more
basic design uses 2x2x.125" aluminum square tube as the frame on top of torsion split axles and 8" wheels (to ensure the tounge weight is about right but the wheels don't interfere with the door, there will be fenders i just didn't model them)
that gets bolted onto a 1/2" 5x8 foot marine plywood floor (maybe I can use regular plywood and just seal it to save weight) with a shell made of 1.5" ridged foam that's reinforced with poor man's fiberglass (and maybe something on the inside that's ridged and light like thin wood paneling)
Doors are pre-made and just need to be popped right in https://www.teardroptrailerparts.com/doors.html
What are your thoughts on the basic design?
Doors
mattress
walls
Axles
outer coating (tinted orangey red to match my car then sprinkled with copper paint)
stabilizer jacks
fenders
I mostly just wanted to get a sanity check for glaring mistakes as I largely have been planning things on my own but pulling information from any sources I can. I do largely think I got the basics down up until I'm in a less stressful financial situation and can play with the materials more. Since i'm getting prebuilt doors (or prebuilt door and window if i just make a twin bed sized version) that just pop into place I don't anticipate needing a wooden shell in something this small (but i could be wrong) providing I'm using PMF and truck liner and thicker foam which will also ensure it's well insulated in cooler and wetter weather, maybe with a battery powered electric blanket for heat.
I'm not an engineer, but that seems awful light for the tongue. If it were steel, I'd say it was light but okay. It wouldn't take much to bend it.
Hopefully, someone with a bit of structural knowledge will chime in.
as far as i can tell it might be, but yeah i'm just going off load tables which wouldn't be as accurate as someoen who knows the metal properties better. the trailer itself weighs 200lbs and the axles are only rated for 600lbs so it won't have a lot of weight behind it. I mean I can likely jump it up to 1/4" thick tubing without having to completely overhaul the design.
The long un-laterally-braced tongue that raises concern for me. Also might want "no step" signs on tongue.
Are you in a state where registering will require inspection?
The tongue and the two parallel bars will be screwed to the wood flooring at 6 or 12 inch intervals which should secure it very well, the tongue might be slightly shorter so the coupler ball is right at the intersection of the two angle walls (to make backing up easier as you can tell if you are about to jacknife easily.)
https://assignedvin.ca/ looks like I do have to go through some steps to get the trailer registered, and it will be inspected.
I thought the 84 was inches and looks like 48" of tongue unsupported. Just seems possible to bend right at point it is under cabin if you loaded it at all or stepped on it. I know its light and you won't put anything in it while towing, but pictures on this site of heftier steel tongues bending at that point.
yeah sorry it is in inches. Measuring in the program the lengths are 26" from edge of the shell to the tip of the bar and 42" from the tip to the cross beam, and I'll shorten it a little so the total length includes the coupling; but yeah I see your point. If i load the trailer correctly there should never be a lot of weight on the tongue (and the front jack will sit just beneath the floor on the tongue). I was doing my best to guess at what the bare minimum would be needed for the frame but I suppose I overshot a little and should switch back to .250" for the bars, might as well make them all .250", and yeah I can add a do not step warning to the tongue.
I'm generally the critic of over building, advocating strong enough, not just strongest. And the impact from a pothole bounce can be a multiple of the load. Test it. Clamp some two-by to the tube approximating the underfloor, and support at axel and hitch points and jump on it.
I applaud you not over building. Much more elegant. Regrettably, we probably cant keep building and testing like Space-X can.
to be fair the most expensive components - axle, doors, jacks - can be unbolted and removed from a broken or failed attempt and attached to a new shell later on. Does mean a loss of ~500 per attempt tho
tony.latham":olt8ge70 said:
The tongue and the two parallel bars will be screwed to the wood flooring ...
Bolts maybe? :thinking:
...yeah, maybe. Assuming I find some that sit sorta flat so they don't dig into the mattress or person
one thing, when using canvas and waterproof glue as pmf for the outside, using truck liner instead of paint at the end is fine?
I wish the design resources included a very simple frame that imho would suit your intents better. Basically a triangle. Instead of a center piece and two parallel at side, a triangle with axel as base and hitch as apex. The "corners" just hang over diagonals. Actually less material and more rigid.
i mean, i did see that, but the angles that tongue hitches come in is somewhat limited, and the front corners and entire back half of the trailer would be unsupported - and i don't trust 1/2" plywood or even 3/4" plywood that much. the designs I saw using the triangle also had a frame of parallel bars running under the body which makes the weight saving a smidge moot.
Build deck of 1/4" ply on 1 or 1 1/2" foam. Roughly as strong as two-by and weight like 1/2" ply.
The frame I recall was just triangle and axel was the base. I really miss that collection of designs.
In my design work if using aluminium its generally larger than steel by half or more - 3" instead of 2" - for portable staging for instance. Don't use it often as generally triple the price for half the weight.
QueticoBill":3fjb39lh said:
...does that plan support .5" plywood floors or 1"foam+1/4"plywwod sandwich floors? It might be more stable then i originally thought, but the design of this trailer means the floor doesn't get a lot of structural support from the body, and I'm not able to get full axle torsion bar sets unless I buy a more expensive one rated for higher capacities (so the trailer will bounce too much), so I'd have to modify the design to have a welded crossbeam instead, but it Might be doable. I mostly avoided steel because it seemed i'd have to use tube steel to make things work which is a major rust risk
And finding 5x8" plywood locally is turning out to be surprisingly difficult, looks like If i make a sandwich the best solution is to have a thin overlapping strip down the center and cut a groove in the foam so it fits over it properly.
No I'm not sure that super light frame is well suited to a foamie. I'd have to do the calculations for the stressed skin panel. Probably 1 1/2" or 2" foam and maybe thicker than 1/4" skins - maybe 3/8.
On steel vs aluminium, there was a recent thread here that, iirc, pretty much was pro-steel. I wish could find it.
Discounting the steel vs aluminum, probably the simplest mod for my concerns would be to add two diagonals to brace tongue. From a few feet back of first cross piece to as close to hitch as possible.
I mean i was able to modify the design to support torsion half axles, but that requires welding on a 4x7" plate to screw the axles onto. Most of the load should be in the front half and not the overhang so idk maybe, I'd be drilling holes 6" apart on each bar to screw the floor to.
Going off gut feeling, i added two 2"x.125" straight bars to support the triangle, and extended the ends another 5" and added a 1"x.125" angle bar. Not as simplified, but it should add more support without adding too much weight or cost. Means the unsupported overhang at the end is just under 20"
Readjusted the design so that the flats have overlap coverage, and so that the plate the axles connect to isn't being welded onto an edge, but I'm not sure how to get that angle bar that the axles plate is welded to more secured.
Hmm, it should be fine. I have a friend who's a good welder and if we prep the edges it's likely to be pretty strong. I'm definitely going to have to pay him in more then pizza tho.
