Rainwater Catchment Ideas for Squaredrop Camper Roof
dt400
Advanced Member
Joined
Nov 28, 2025
Posts
47
Location
Colorado
I am building a squaredrop camper, flat roof but usually could set it up slightly head up so the water will run to the low end. The way my roof rack is designed it will keep water from running off the sides so it will all run to one end.
I have a few ideas to capture rain water and funnel it into a 5 gal container to be purified later. I have used tarps in the past but since the camper already has a large flat area to capture water this will be much easier.
The sloped roof will direct the water to one end, then a raised bit of material will will send it toward the center of the edge where it will fall into a small capture (funnel/gutter etc) then down a hose into the container. The idea is to keep the funnel rather sleek and small, I don't need an actual house gutter, with a removable hose.
My question is has anyone done this and do you have any tips or found any trick components that helped the build process?
Thx.
Darrell
I've seen my awning catch a ton of rain and poor it over the corner.
cascade it onto a small PVCpvs pipe with slots cut into it. heavy debris will slide over while the water droplets will be deposited inside
Look into j channel trim (I'm looking at ways to move water away from the rounded corners of my hatch and that seems the most promising) there are plastic and aluminum versions of it that might do the trick (and it is pretty low profile
