Raptor Bedliner Over Fiberglass: Epoxy Coverage and Sealing Prep
Thread Summary
Summarized on:
Original Member Title: Bedliner coat prep. What am I missing?
A member preparing to spray Raptor bedliner over epoxy-sealed, fiberglass-covered 1/2-inch plywood asked whether the exposed weave provided enough adhesion and moisture protection without another epoxy coat, and whether liner texture could interfere with sealing fixtures. Multiple members recommended sanding rather than relying on weave texture alone; one suggested contacting Raptor because the technical data sheet did not cover the exact application, while another recommended fully...
More...
TheHoboHouse
Member
Joined
Jan 26, 2026
Posts
15
Location
Colorado
Hi builders! I've got Raptor liner (bedliner) I'm planning to spray on. Beneath that, its 1/2" plywood that's been:
1. sealed with penetrating (thin / marine) epoxy (esp. edges), then
2. fiberglassed (6oz, grid weave) with enough epoxy to wet it out (single coat), but not enough to cover over the full weave.
I'm thinking the weave texture coming through will help with mechanical adhesion of the bedliner, and that the sealing coat + this wet-out coat is enough epoxy for preventing water issues. But before I start spraying liner, I wanted to check if anyone has had good/bad results (recommendations) with using a similar process.
Question 1: The main part I am concerned about is the decision to not put on one more epoxy coat to completely cover the fiberglass weave (and then sanding it with rough grit for liner adhesion). Is the saturating coat + the single wet-out coat over the fiberglass + bedliner enough for moisture issue prevention? Or should I add another full coat of epoxy before the liner? (If its good as-is, I'd prefer it for what seems like would be the superior adhesion of the liner to the weave texture.)
Question 2: I'm assuming i put the liner on and then attach/seal (butyl, etc.) the doors and window, lights, etc., over the liner. Anyone had issues here with the texture preventing a water-tight seal? Any reason to do this differently?
Thanks!
What you're missing, is that the TDS doesn't have a procedure listed. That matches your exact application. You are going to need to contact them, if you want an accurate answer.
I'm guessing, you're going to have to sand it.
The non-filled cloth weave. Isn't regarded as having any mechanical adhesion properties, that I'm aware of. Typically epoxy needs to be sanded. ( once fully cured ) Or, a peel-ply cloth used, during lay up. Prior to any additional coatings or lay ups, being applied.
Thanks. Yes, I think the texture not being smooth (like it would be if there was another coat) is what gives it some mechanical adhesion, but also think you're probably right that sanding anyway is still a good idea, to prevent any non-porous glossy spots even if they're just tiny and on the protruding part of the weave. So a rough-up sanding seems like a lower risk way to go. I guess I could always use some spray on adhesion enhancer as well... It's quick and easy and couldn't hurt.
I'm just hoping that overall there's enough epoxy on there for moisture protection.
I too think you need to sand before painting for the tooth effect. I assume you know about epoxy blush?
With Monstaliner, they recommended I prime before application.
And yes, get the finish done and then seal. For many applications, I prefer Lexel sealant over butyl tape. The tape is just too thick. (I do use it under the fan in case I have to replace it sometime.) I've never had an issue with leaks.
Our feeling was that we did too much up to that point to risk any experiment that might fail after a few years. Better to follow the proven path.
So if it were me, I’d sand and add another coat of epoxy to fully cover the weave. Then sand, prime, and only then apply the bed liner.
Thanks for the tips! I used the non-blush epoxy/hardener (350) from Raka. It's been nice to work with.
I'm definitely now leaning toward another coat to cover the weave before the liner.
For anyone stumbling a cross this thread:
The initial thought was that the weave would give superior adhesion versus a smooth-then-sanded surface, so I was aiming to avoid the problem that others have had where the liner peels or pulls away and leaves gaps, as well as avoid a full rough-up sanding if possible. I figured the sweet spot would be where the wood is glassed/epoxied enough to prevent cracks/checks that would affect the liner, but with better-than-sanded alone texture to give the liner some mechanical bite to attach to. (BTW, AI seems to say this is a good way to go, but I don't trust it over experienced builder advice.). Since the liner texture is gritty, I also didn't care about a smooth underlayer. But...
But it sounds like a smooth second coat and then sanding (with blush removal firsr, if that was applicable) would have enough adhesion (maybe also with primer / adhesion spray) to work well, while letting me sleep at night that the epoxy is thick enough. So I'll err on the side of overkill on the epoxy.
Thanks. Leaning that direction now.
I was initially trying to avoid the risk of the liner peeling away / gapping over time, thinking that the weave texture would give it great (not just good) bite/adhesion.
I was hoping the the "not enough epoxy" risk was lower due to: 1. Penetrating/Sealing epoxy first. 2. 1/2" ply + glass with some epoxy being enough for tensile strength and moisture issue prevention. And 3. Bedliner + trim serving as an extra layer for this.
AI seems to love the idea. 😂
But you're right that multi-coat epoxy with a good rough-up sanding is the battle tested path, so it's probably worth sticking with.
I'm going to play devils advocate here. FWIW I built a foamie with several layers 12oz glass and epoxy resin.
I think 1 coat of 6oz, glass isn't enough for corners. I'd do at least 3 getting wider with each layer by a couple inches. epoxy itself isn't strong...the glass gives it strength. I'd glass the entire thing actually. but 6 oz is still thin IMO.
I did Monstaliner like another poster did and used epoxy primer before the liner. Call Raptor and ask them. Any short cuts now aren't worth the problems down the road.
I use OSI Quad Max sealant for main doors and windows. Used the butyl tape for the cargo doors and vent fan ( along with Dicor around edges/screws) I have a raised curb around my vent so water won't even reach the sealant until it's 3/4" deep on the roof. I did some destructive testing and the OSI and Lexel ( if you need clear) have better adhesion than either the 3M marine 4200 or 5200 on the Monstaliner. Cant say what will work best on Raptor.
Darrell
Well.... I didn't do any on my roof-to-wall edges, and after seven years, no issues. However, my edges are mechanically sound:
Is it a good idea? Yes.
I have no idea how many folks have used my book to build their teardrops, but it's been a fleet.
I've been in contact with dozens through their build and beyond, and nobody –who has followed the book– has mentioned an issue with the wall/ceiling joint. Perhaps they ran glass tape along the edge, but if they did, I didn't suggest it.
But, it is a good idea.
