Repairing Broken Galley Door Lift Attachment on OK Schooner Teardrop
Thread Summary
Summarized on:
Original Member Title: Galley door problem
A member with an OK Schooner teardrop trailer is seeking advice after a galley door lift broke away, leaving a hole in the wood lining and making reattachment difficult. Several experienced RVers responded, noting that the best repair method depends on the extent of the damage and the specific hatch construction. Suggestions ranged from simple fixes like using toothpicks and glue to fill the hole, to more involved repairs such as inserting a new piece of wood. Members emphasized the...
More...
mollypcb
Senior Member
Joined
Oct 25, 2008
Posts
133
I have an OK Schooner, a traditional teardrop shape. One of the lifts on the galley door broke away from the wood lining the galley door. The break created a hole in the wood lining so I can’t reattach the lift. I am not sure how to patch the wood to reattach the lift. Ideas, any help would be appreciated. My teardrop is covered right now or I would add photos.
Tony is correct. There are different ways to fix such a problem, depending on how bad the problem is. Sometimes, it can be a simple as some smashed toothpicks and glue, but other times, (probably most) it can require the insert of a new cut of wood. And, yes, it can depend on how the hatch is built, too. Uploading a picture would be best.
This, by the way, is how I suggest attaching the struts.
But it's not something that can be retrofitted.
I'm not sure if this image will help, but it might get the thought process going.
Years ago we were camping in high winds and the screws on the strut bracket came loose because they were in plywood end grain. I cut a house door hinge in half and welded it to that bracket so now there are additional screws going into the face of the plywood framing. It now withstands anything with the exception of a tornado or hurricane.
:D Danny
New posts
