Roof Vent Flange for a Hybrid Foamie Build
Chefsonora
Advanced Member
Joined
May 5, 2026
Posts
61
Location
Sonora, CA
So im doing the last of my framing (hybrid Foamie) and im curious about placing the roof vent. Do I need to build up a lip/flange to avoid potential leaks? Or should I just do a slight arch to shed water away? Any tips or general rules? (Install guides that I see are generally about the 14" x 14" hole, but they seem to talk about replacements, not construction)
I suggest cutting it 14-1/4" square. I seal mine with butyl tape and then put a bead of Lexel around the edge. There's no need to build it up.
I have a slight radius to my roof where my fan will go and I chose to build it up enough to be a flat surface. Since my Maxx Air fan has a rain enclosure and is already pretty tall, I didn't want to make it any taller, but I also didn't want to stress the plastic by trying to force it to the shape of the roof. The raised area, if you can call it that, was easy to fair into the curvature and isn't really very noticeable. On the other hand, if your fan shroud is short and you don't have clearance concerns (like trying to make sure you can get your camper into your garage) adding a short berm all around sounds like it would hedge a bet against future potential leaks. On the third hand, Tony has a lot of hours on the road with his multiple builds and I'm sure gets plenty of feedback from people using his methods, so if no berm is good enough for him, it's probably not necessary.
Im ready for the last of the first coat of penetrating epoxy to seal all the wood up.(started with Total Boat, finishing up with Raka). Got my stargazer dome hole cut and "framed". Framed out the vent hole. Not liking the raw plywood look(on the floor ,where it will be exposed) , but avoiding oil based stain to give the epoxy its best chance to seal the wood. Anybody tried the old vinegar and steel wool stain under epoxy?
New posts
