Rose Rolls - The unathorized Compass Rose autobiography
And reply #400 to celebrate 81118 views of the thread.
Y’all are an inquisitive bunch. :thumbsup:
Because a teardrop is never “done” I made some more changes. I’ve recently added a 45l fridge to my tow vehicle, so the ice chest is redundant. Why the TV, because sometimes I adventure without Rose.
At the same time, I recently acquired a 5# propane tank and wanted to find a nice spot to stow it. The configuration allows for adding waterbricks for those times the 11 gallons in the TV might not be enough. Removing the microwave when I’m without shore power allowed adding 3 waterbricks. I can add 2 or 3 more now. Spatially, the weight of the waterbricks is just behind the axle, so no real effect.
Looks so spacious in here.
image.php
Tank bracket. It’s really a 20# fire extinguisher bracket without the 3x overland tax added.
image.php
Home at last.
image.php
Waterbrick tryouts.
image.php
image.php
Since Rose is a teen now, she’s well into acne time.
Her varnish is showing some effects of time. I had planned to refinish her last winter, but storage options didn’t allow me access. So it’s spot finish time.
image.php
The spot that made me look. This one got wet on the last trip. Ughhhh.
image.php
I saw this today. Bears a lot of watching.
image.php
bdosborn":1evibk9l said:
Water leaks?
No leaks, just needs the finish resealed.
The corner of the door I think is from water wicking up the screw holding the trim on. Not sure how extensive that one is.
Sparksalot":mhw6kgli said:
bdosborn":mhw6kgli said:
Water leaks?
I might need to do some epoxy impregnating there.
As a fallback, I’ve always thought if the wood finish was ever too compromised, I’d look at an OD army tear look.
Rose has had an issue for a while with sneak circuits discharging her battery. I’m guessing the added USB outlets and digital voltmeter, etc.
During the year of unpleasantness, the drain was so deep, it destroyed the battery. I had planned to add a master disconnect for a while, so with a new battery in place now is the time.
image.php
The dangly down cable is much more taut. The others are power feed from the TV, and feed from the battery to the controller.
image.php
Since Rose is now 15, I figured it was a good time for the 4th spar varnish refresher.
I also realized the finish below the fenders had never been refreshed. Note the darker, original, color.
image.php
image.php
I remember there was an EPA mandate and they had to change their formulation. I wonder if the new recipe is as good as what you used? I used it for the wheel wells on the trailer after I saw your tests.
I thought I had heard about it being pulled from the market. Sounds like it was a reformulation then. It’s too bad I have none of the original stuff to test against the new on the same piece of wood.
Time to wrap it up, there’s a trip soon.
image.php
The 3500# axle she got 2 years ago.
image.php
With a fender and Hobbit menu
image.php
Curb side is shiny too.
image.php
image.php
image.php
She even has hubcaps now.
image.php
Being a teenager, of course she has zits.
image.php
image.php
Really, each zit represents a spot on that side which needed extra attention.
Next up, work on the doors. The lower trim on the street side door has been a headache since I built her.
image.php
WTH, I just refinished this side. After 3 nights of torrential rains. No issues on the curb side.
image.php
I recently pulled the crime scene awning off of thecopcar, so Rose has double the shade installed now.
image.php
image.php
