Running the same wheels as on the truck? Offset
rebar
Senior Member
Joined
Nov 19, 2010
Posts
474
Location
iowa
Ive always thought it would be a advantage to have the trailer setup with the same exact wheels and tire size as on my truck so I would only need one spare. But the wheel offset of the truck is 4 3/4", while the trailer rim is centered at 0 offset.
For those of you who have done this.. Did it require a wider axle so the tire wouldn't rub on the inside?
Thanks!
That depends on your build and how much space there is. The other common issues that arise are the bolt pattern and the center bore of the wheels fitting over the hub. You can get hubs with some different bolt patterns but many wheels have a smaller hole in the center that is not large enough to fit over the hub. Wheel spacers/adapters solve both these problems (and may solve your backspacing problem).
Ottsville":megej07a said:
Many wheels have a smaller hole in the center that is not large enough to fit over the hub. Wheel spacers/adapters solve both these problems (and may solve your backspacing problem).
Thanks Ottsville..
Are you saying the trailer rim center hole would be larger than the 3/4 ton truck rims 4.77" center hole? Or smaller? Is it important that the center hole fits snug on the hub?
Thanks again!
many years ago horse & stock trailers were outfitted w/ axle hubs that accepted the wheels from 3/4 & 1-ton pick ups
16" x 6 lug using 7.00x16 & 235/85x16 tires
this made the OP's premise work and work well(try to even buy a 7.00x16 today)
since styles and fuel economy have become major factors in designing pick ups that old standard has gone out the window
OFFSET & WHEEL CENTER HOLE SIZE are major factors when designing a trailer axle and wheel well to accept the TV's wheels
these factors must be considered in the design stage of trailer building
luckily i wasn't far from home when i had to use the Jeep spare on my trailer because that tire rubbing on the frame sure stunk & smoked :shock:
sw
Thanks again!
Short answer is that the hole in your wheel needs to be larger than the hub on the trailer. Many Jeep wheels are the same bolt pattern as many light trailers (5x4.5) but the the center holes are not large enough to fit over the hub.
Your last question is getting into hub centric vs lug centric questions. I had a really good link on that but I can't seem to find it now. You can get adapters/spacers that work either way, but make sure you are using correct lug nuts if you switch from hub centric to lug centric.
Im reading about hub centric vs lug centric and I still have the same opinion..
If the wheel was press-fit onto the hub I'd get it. But the wheel has to be a slip fit so that means that with manufacturing tolerances the hole in the wheel will always be bigger than the diameter of the hub, so the tapers on the lug nuts do all the wheel centering and the hub doesn't support anything, unless the lugs bend.
Just my opinion.
I'm wondering how trailer makers will react to my request to widen the axle 9-10" so that they can fit offset truck rims.. They'll probably hang up on me. lol
rebar, simply remember you are the one w/ the $$$ and there is/are manufacturers out there who are in business to make $$$ ;-)
sw
It's not uncommon to have axles made to specific measurement. Axles can also be extended/shortened DIY.
Thanks!
I think you are confusing backspace with off set.
Yes trailer rims are a 0 offset off the center line. Offset is measured in negative mm's and positive mm"s, such as -12 which would move the hub 12 mm to the back of the rim which in turns moves the wheel out from the car/truck.
Backspace is measured in inch's from the back of the rim to where the hub out mounts. your 4.75" you list is backspace. Depending how wide your wheel is will tell if you have a + or - offset. On the inside of the rim it will say what the offset is.
You can measure from the side wall of the trailer to the hub face and get an idea if it will work. But the tire can be wider than the rim width so take that into account.
Like has been said the wheel bore and spindle diameter will be the biggest issue. If you have aftermarket wheels that may help because they may have bigger bores to fit more vehicles. Another issue being its a 3/4 ton is the bolt pattern most likely will be 8 lugs. Most trailers are 5 lugs. You would need to know your bolt pattern on your trailer and truck and see if you can get an adapter (NOT spacer) to fit.
I am going through this now on my build and the bottom line is it is spendy to put car/truck/jeep wheels and tires on a trailer.
Todd
Thanks!
Todd
Thanks and yes I needed a little education regarding offset and back space. I think what first threw me off was finding this.. http://www.dodgeram.org/tech/specs/wheel/specs.htm
1994-2002 dodge 2500 2WD/4WD Steel Wheels:
Lug Pattern - 8 on 6.5", 9/16" bolt
Rim Size - 16x6.5"
Offset - 4.75"
Max Tire Size - 245/75R16, 255/85R16
But your saying offset is measured in mm, so Im not convinced the above information is accurate.
Thanks!
Todd
Rim Size - 16x6.5"
Offset - 4.75"
I think let just used Offset for Backspace, not a big deal.
If you can just put a trailer tire and truck tire and see what you have. Then go from there. The other thing is do you have room under your fender for a bigger tire?
Todd
Rim Size - 16x6.5"
Offset - 4.75"
Given the above information, if the rim is 6.5" and back space is 4 3/4" that would mean it has 1 3/4" or 44mm positive offset?
I have neither the elusive dodge 12 valve 4x4 5 speed, or the narrow track trailer Iv been searching for for quite some time. I started talking to MTI king trailers about a narrow track enclosed but never got into details if they would build it with truck rims and tires.. Now that I know a little more thanks to you guys, I will have to call them back and cross my fingers because if I found a used trailer, it would probably come with 5 lug axles anyway.
Does anyone know if one can replace 5 lug hubs on a 3500# axle with 8 lug hubs?
rebar":3ctl3msf said:
If the rim is 6.5" and back space is 4 3/4" that would mean it has 1 3/4" or 44mm positive offset.
That would mean a adapter from 5 lug to 8 lug 1 3/4" thick would put the truck rim at 0 offset. :worship:
Ottsville":1loelzvc said:
Check the axle manufacturer's website to see what bolt patterns they offer.
I guess my point is if I ordered a 7k# axle to get the 8 lugs, the truck rim would rub on the trailer without a spacer anyway. It just dawned on me that simply using the stock 3500# axle with 2" spacers will get a truck rim close to the 0 offset I need! Bingo super easy peezy
Look on Etrailer and they have idler hubs with 8 lugs. If you have breaks you can get drums with 8 lugs.
Did you pull the trailer wheel off and measure from the face of the hub to the wall of the camper? What is that measurement? Also what is the the bore on the wheel?
Todd
Jeep wheels do fit the std Dexter (and clone) D30 and D35 drum brake hubs. It's as if they were made for each other. That's what I have on TPCE.
Todd
I don't own a trailer yet.. But from what Iv gathered I should order the trailer with 5200# axles, or what ever it took to get 8x6.5 if I do buy new. Then buy 3500# leafs not to tear the trailer up because it will weigh in close to 7000#.
Problem is, I'm not happy with any companies version of yester year's narrow track enclosed trailer. And also second guessing myself about dual axle..
I may be wrong, but I think leaf springs are rated by the pair. So a couple of 3500 lb springs support 3500 lbs. I would be happy to be corrected by a legitimate information source.
I have YJ leaf springs under my trailer and they are quite flexible at a 1750 lb rating, even on the bare trailer frame; so I am convinced that they would not support 3500 lbs combined.
Hope that makes sense.
Just make sure the off-sets match, you don't want to change the load on the bearings.
image.php
image.php
New posts
