I've been working on painting the trailer frame and I don't think it's going well.
Here was my process;
1. Thoroughly and completely strip the metal surface bare, removing all rust, paint, mil scale, everything
2. Thoroughly sand all surface with 60 grit sand paper, even the crooks and crannies
3. Spray the metal with acetone, wipe the surface. Repeat until every surface produces a clean paper towel with no hint
4. Spray on 2 coats of Rust-Oleum Primer
5. Allow the Primer to sit for 24 hours before applying paint (per instructions)
6. Using Rust-Oleum 'Professional Grade' Oil-Based Enamel, I mixed with a drill-bit mixer, I rolled on a coat. It was on the thick side.
7. Wait 48 hours (as per instructions), checked the coat. The primer looked dry but I was still able to press my finger nail into it. It felt similar to a slightly stiffer than normal piece of cork from a wine bottle. The instructions stated wait 48 hours between coats, so I applied the second coat.
8. Same as 7.
9. Wait
It has been 4 days since I applied the third coat. The Rust-Oleum enamel is still soft, it does not appear to have gotten harder. For some environmental context, I live in a desert and the humidity is essentially 0%. The frame is also in a temperature controlled environment, around 70°C. This is within the manufacturers recommendations (unless I'm mistaken...). I also did not use a hardener, because I didn't know they existed and there is no mention of that in the instructions.
At 96 hours, I feel like this should be complete. This is costing me extra money to store my trailer frame that is getting hard to afford so this is beginning to stress me out. I also have to dance around the trailer like I'm dodging lasers to access my rented space, and so far I have managed to damage it twice on day three after the third coat. I piece of wood hit the frame and scraped the paint to the primer or the metal (I can't tell which).
I don't understand exactly what it is I'm waiting for. This product has been pretty well reviewed here, but from what I'm seeing I feel like 1 mile on a dirt road is going to make the Rust-Oleum enamel appear as if it took a 30 foot hit from a shotgun. The fender coating won't be able to handle any road with a any loose material. There's absolutely no way I could put the trailer on the frame without scraping off the enamel, even with a roller to prevent scraping. I feel confident I could scratch it off with my nails if I really tried, even 4 days of curing.
Is this normal? Other sources online say to wait waits to months for it to fully cure. I don't have that luxury. I'd also prefer not to spend the time and money to reclean the metal for another product, but I will if I have to. Feeling lost here
8. Same as 7.
9. Wait
