GarySaunders
New Member
Just wondering what people are using for the underside of the floor? I was thinking Rhino bed liner or flexseal, any thoughts on this or is there a better product out there?
How many coats do you go with, and what was the process like?As mentioned, I argue for epoxy. It soaks into the wood and plasticizes it. Raka makes a good product and isn't too expensive. Buy their pumps.
Some will argue for roofing tar, but this isn't 1938, and you don't want to end up in the La Brea tar pit.
That image is for the poly coat on the topside. So pour directly and use the squeegees sounds like the approach
Yep, that would be me. Four TDs with black jack and no problems since 2016! Sorry Tony, sometimes the old ways work just fine. : )...
Tony I just put 3 coats on my outer floor or base layer this past week. I put on a good coat of MAS marine epoxy waited on it to dry then sanded it then two more coats including the edges of the plywood.As mentioned, I argue for epoxy. It soaks into the wood and plasticizes it. Raka makes a good product and isn't too expensive. Buy their pumps.
I don’t think I’m even gonna use bed liner over the epoxy. The marine epoxy itself imo will be sufficient.Yep. I did two good coats of Raka epoxy, some light sanding, and then followed it up with spray on bed liner.
