pfennigcat2
Member
- Joined
- Apr 20, 2018
- Posts
- 15
My previous/current camper is Wee Frilly, a Carawhale copy: Hello from Central Texas. It is great, but not easy to get in and out of, it also being a boat and all.
I'm in the planning phases of a new camper for DW and myself, though in all honesty construction is likely years away.
Summary of my requirements:
The whole "foamie" portion will have a continuous hurricane hinge at the front of the trailer platform, so it can be tilted up and forward to roll the Morgan out. The rest of the time the most reasonable way I've found to attach the shell is by the addition of 1x6 boards that bolt to the sides of the trailer platform and then are through-bolted through the bottom of the foam sides. The fiberglass will wrap the bottom edge of the foam, so I believe the connection will be solid/durable. The 1x6's will be wood but can easily be replaced if they become worn/weathered at any point (I'll probably just epoxy coat them then paint).
The interior will be 'empty' by default. When used as a camper, I'll add a platform (even a bunch of milk crates?) and a full-size mattress, a powered cooler-fridge, a porta-potty, even a single cot in the front to allow a guest. Cooking/dining will be outside by default. When it transit everything will be strapped down or in the tow vehicle (a Toyota Sienna Hybrid).
I'll be taking my time with the design -- as I said, it will likely be years before I actually build it (Wee Frilly is still usable!). But designing is fun and if the design is solid I can build the trailer frame much sooner so I can self-rescue if/when the Morgan breaks down on the side of the road (it'll happen at some point and I don't want to make tow truck operators think too hard... or pay them). So for the next months/years I'll be examining everything from every possible angle that I can imagine... and hoping feedback here will help me imagine things I havent yet! Like:
What havent I thought of? Any thoughts, criticisms, references, etc welcomed!
- Amusing -- we love the attention that Wee Frilly gets, and this one will be a SHARK!
- Standy -- easy to get in and out, easy to be in, but needs to squeak under an 8ft garage door
- Foamie -- light weight
- Dual Purpose as a utility trailer and toy hauler
- Airconditioned -- we're the Disney Fort Wilderness type of camper, not boondockers
- 12ft 1in by 7ft 2in (145in x 86in) trailer platform
- Main tubing 2x2 with 3/16 wall, thinner c-channel for cross members
- Tongue 3x3 and 2x3 on the angled bits
- 2500 lb FlexiRide torsion axle
- ~6 degree up angle to get the platform relatively low despite full size wheels/tires
- CAD-estimated 1100 lb for the camper (the Morgan weighs 1200 lb, so 2300 lb combined -- tow vehicle is rated for 3500)
- Surge brakes
- 2 in thick XPS foam construction, with 1 layer of real fiberglass on the inside, 2 on the outside
- As close to zero wood in the top as I can manage.
- The whole top will be both hinged/openable (toy-hauler) and removable (utility trailer)
- Is the hurricane hinge and side board attachment good enough for such a large camper at 60mph?
- I thought about fiberglassing in composite L-channel to bolt down to the trailer surface rather than the outside, but I like the latter better so far.
- I thought about wood in the bottom edge of the shell, but don't think it would actually improve strength (just need to make sure the through-bolt spots are reinforced to prevent crushing the foam?)
- Is this really really just "too big" for a foamie even with fiberglass/epoxy and internal supports?
- Will a keder rail VHB'd to the top edge be strong enough to attach an awning when camped? Or risk damaging the foamie shell in strong wind?
- Can I really lift the top to get the Morgan in and out?
- My plan is to use 8ft long acme screws on each corner, driven by a power drill, to lift evenly with one person. As long as I don't bend the acme screws during transit this seems like it ought to work better than trying to (for example) pull laterally against the tow vehicle's roof rack. After fiberglassing, that top will probably weigh a couple hundred pounds
- The door will be all-foam as much as possible, and suicide-hinged -- I plan both a residential deadbolt and residential handle to secure the front edge at different heights during transit. Will this be enough?
- Will I actually be able to get the Morgan on the trailer with a winch pulling it up and over the trailer tires?
- I think yes, this is why there's a hole at the front of the shark's 'nose' for the cable to pass through, and that will double as where AC ducts attach, but how about getting it off again?
- I think I can have a winch on the tongue pull it up and pull it off by putting a pulley at the back... and having someone working the brakes on the Morgan for control. Morgans dont have a reverse gear.
