Summer Travel
New Member
Hi All,
I recently purchased a small 4x4 trailer from Costco that arrived in a kit to assemble.
The slipper side of the leaf spring sits directly on top of two bolts which I feel something is not right.
The holder bracket is mounted to the frame with two bolts, but the slipper side of the leaf spring sits physically on top of the bolts. I am not sure if the spring is suppose to rub directly against the bolts.
I had already contacted the vendor (provided by Costco), which they insisted it was correct according to their "manufacturer".
Attached is a photo showing how the spring sits on top of the bolts within the bracket.
I am hoping someone would be able to provide some advise or insight would be great!
Thank you.
Thank you.
