Step 12: Run 12v Wiring – security cable
This step is a mouthful. I've posted my rough draft today, but there will be changes, and additions... definitely additions... If you see anything I missed, please let me know...
Thanks,
Wiring. The mere sound of the word scares some people. But it’s really not that hard.
Lets look at an overview of the inside wiring first.
Just like in the first Benroy I built, this design has an electrical raceway under the cabinets in the cabin. This raceway is nothing more than a box to hide all your wires and plugs in. The electrical comes in once side of the raceway, and there are 12V plugs and 110V plugs on both the cabin side and the galley side of the raceway. The first plug on the 110v side is a GFI plug, which acts as your fuse. The 12v side has a fuse for every circuit. Finally, there is a 12v converter that turns your 110v power into 12 v power for lights, vents, fans, mattress warmers, tvs, etc.
Here’s the parts you need to get
110v Inlet
12 gauge wire for 110v circuit
Electrical box for every plug you want
Electrical outlets
One GFI electrical outlet
12 v converter
12 gauge wire for 12v circuit
12 volt plugs
12 v fuse box
Bus bar
Sound cable 16-2
¾” pvc conduit
Make the electrical raceway by screwing a piece of 1x4 underneath the cabinet and another 1x4 5 ½” below that. The front of the raceway will be a piece of 1x6 either screwed on or hinged. Michael W did a beautiful hinged version of the raceway.
http://tnttt.com/viewto ... 6278#36278
At the end of the raceway, on the drivers side, drill a hole for the 110v inlet, and install.
Cut out your rectangular holes for your 110v plugs in the bulkhead wall and also in the raceway front.
Drill your holes for your 12v plugs in both the bulkhead walls and the raceway front.
Mount the 12v converter on the bulkhead wall, either the cabin side or the galley side.
Run the wires from the 12v converter to the fuse block and the busbar
Drill a hole through the top of the cabinet, through the bottom of the cabinet and thru the raceway for a piece of conduit. Press the conduit into the hole, so that it’s flush with the top and bottom of the cabinet.
Pull 16-2 wires from all the lights locations, vent fan location, and 12v plug locations down through the conduit in the cabinet to the fuseblock and busbar. You’ll be drilling holes thru the roof spars to pull your wires. Try to place the wires exactly 1 foot from each edge. Later when you attach your roof, you’ll avoid the area 1 foot from the edge, so that you don’t accidently put a nail or screw into your wiring, causing a short.
As you attach each light to the wall, you’ll connect the other end to the fuseblock and bus bar as shown in this photo.
Connect the 110v wiring as shown in this photo. Test the 110v circuit.
http://www.electrical-online.com/howtoa ... esters.htm
Turn on the power converter. Test the 12v circuit
http://www.pilotstore.com/store/item.asp?ITEM_ID=1544
Later when we install the hatch we’ll be pulling some more wire into the electrical raceway.
Thanks,
110v Inlet
Electrical outlets
12 v converter
12 volt plugs
12 v fuse box
Bus bar
Sound cable 16-2
¾” pvc conduit
