Senior Member
- Joined
- Feb 9, 2006
- Posts
- 15,200
You’ll notice the bottom “Membrane” which is a plastic sheet placed underneath so they don’t have to take the time and expense to properly undercoat the bottom . It takes them much less time to throw a plastic sheet down and build over that ... They don’t even glue it to the floor bottom ...
.... we’ve actually seen many many cases where that plastic sheet HOLDS WATER and moisture in , sometimes like a big bubble underneath FULL of water
... certain to quickly ROT an untreated floor ...
And we’ll not even talk of the roof , which seemed designed to fail ... and then there were the revolutionary “dry fit “ windows they boasted of , which also leaked and caused de-lamination of certain wall members ...
Questions, Which HF trailer did you use (weight cap), what size tires did you end up using ?, What is the size of your sub floor structure (LxW) ? Last one , What is the size of the bed area ? Sorry to ask all of this. But it's a long topic (many, many, many, pages) I'm sure that some of the answers are their
