the jelly belly build
Miriam C.":zl11ig8c said:
:applause: :applause: :thumbsup: Great idea. Now can I please get a picture of the bracket on top. :twisted:
This one??
I got it used, buut iit can be purchased new. Some dealers will nott ssell aa sshorrt piece.
del
Well it is time to start figuring out how in the world to mount this new axle.
Put the axle in front of current axle.
Yes I centered it, and it is wider than the old axle
Now for the puzzle, the outside of the brackets for axle is 53", and the outside of the frame rails are 40". Can I press the spindles out, with the rubber bits and move the the brackets? Ideas welcome. I leave you with a pic of the original mounting brackets on the pop up frame.
del
The rubber got in there by being frozen in liquid nitrogen, so you won't be able to cool the axle enough to get the rubber and spindles out.
You could cut the middle 13" out of the axle tube and then carefully weld and reinforce the centre joint, taking care not to 'cook' the rubber with the welding heat.
Andrew
You should have no problems cuttinng out the middle of the axle tube, as the rubber only goes in about 18". I had to do this when i narrowed mine
Ok I not any help on the axle but I got a question on the awnings class.
Where did you get the track to slide the awning into?
Andrew
With my new wheels, the wider is the only way I can go, and not put in wheel wells.
Tyre size 450/18's. The wheels are still in Kansas.
I am thinking (I thought of this at 3am last night) if I build sort of a box, that bolts to the frame on the inside, and the fender at the top (hey the fender will let my fat self stand on it without moving). Thoughts, concerns.
thanks del
I got that used from my uncle. When I priced it last winter (from Tom's rv near Tampa) it was $3 a foot, but here is the kicker I would have to buy the entire 20' stick. Call around, it is an awning track thingamabob.
del
del
Thanks for the info, I'm headed to my local junck yard they've got 3 RV's I've been scavenging parts off of I'll have to see if one has one on it.
If you don't find what you need at the junk yard, Rochford is a pretty reliable supplier for this sort of thing...here' s is a link to their awning rail....then you get the beaded welt that you sew to the awning fabric...
Time for getting ready for Nebraska, nothing like a time crunch to get things done. The black goo is peeling on the the leading edge and the very back. Cleaned it up with a wire brush and reapplied goo.
A drain at the rear most point of the trailer made sense, but in practice not so good. Oh well more fiberglass.
I did check the bearings and brakes. The bearings and brake shoes were fine. I am guessing the electro magnet pulls into the drum, and spreads the shoes apart.
del
To get to Nebraska on time, I will be leaving Sunday. I will be taking I-90 out of Ritzeville to I-94 at Billings. Staying on 94 till US83 (in N Dakota) then heading south towards Minden. Hope to see some of you nice folks there.
del
Well I made it to Kansas, on the way back from Nebraska. I brought back my wheels.
I abandoned the axle to the junk man. Only wide enough for a 48" tear, and I was limited on space. Bye axle.
Took a pic of the tyre size, but from the first pic they are not fixable. These are going to be spendy, will motor cycle radials work?
del
Just wanted to make a little note to people. If you have brakes you have a left and a right. Note the bigger shoe is in the back, smaller in front. The way I remember is Big in Back.. Same as cars with brake shoes.
Nice photo. Fantastic trailer.
del
Del, I was zipping thru post saw the tires. Try a place called Coker Tire
http://store.coker.com/search.php?m...utmctr=coker tirees&__utmv=-&__utmk=138633651
This should be the exact page you need for those 5 plys. i was restoring my grandad's 54 Chevy carry all suburban, and it too has the 5 ply tires.
Hope that helps.
dwatts5250":3idr4jn1 said:
del
Hope that helps.
Welcome, and thanks for the link. I always liked the 47-55 1st series trucks, any pics?
del
Thanks! Ive got alot of work to do ahead of me, on both a TD and the burban
ive got a few from when i just dropped her into storage, havent had alot of money to fix her lately..have had more freetime, as I joined the unemployed a short time ago.
ill post em in my album...cuz i cant seem to get them up here.
This last week end I traveled to Lyden Wa for a Tin Can Tourist rally, and had a wonderful time. I did take pics, but none of my trailer by it self. I was there to visit with new and old friends, and look at their trailers. Here is one with a john wayne western theme. All that stuff is transported in thee 47 tear.
And here is proof I was there.
del
