dbhost
Senior Member
So as I mentinoed my need for a king bed is gone. My wife passed away. I am now going to travel FOR her instead of WITH her.
After this build is done, the innaugural trip will be pretty simple just a weekender over to Bolivar Peninsula and camping on the beach of the Gulf of Mexico. If that goes well, I will head further out, most likely to Padre Island national Seashore to one of the remote 4x4 only camgrounds, and then inland...
So in order to expedite the build. I am starting off with a used hi top camper shell. Not a perfect fit, but I got a Jeraco hi top that had been on a 2007 classic body style Chevy Silverado 6.5 ft box truck.
The ways it doesn't fit can be made up with foam sealers and I really don't care about cosmetics.
And the topper was CHEAP. I almost wish I had a Chevy to put it on to get that perfect fit, but this will work... Cab height is right, it is just the topper overlaps the bed of the truck length wise by about 1/2". Looks a little funny and leaves a gap. I can fix the gap.
I need to figure out how to make images work since mine are hosted on Google Photos.
I got the camper shell home yesterday, I had to replace the 3rd brake light, which I did this morning. The original had cracked and was leaking into the cab. Once the light was replaced I washed the widows and basically anything that would be unreachable once the topper was mounted. Thus the huge gap... The topper is now slid into the right position.
Some background.
The Truck. 2004 F150 XLT 4x4 Supercab I bought when I was dating my wife, and we were talking about the potential of having kids. So I wanted a back seat... It is also a bench seat model... It has a now failed 5.4L 3V Triton V8, not one of Fords better ideas... I am getting a Jasper Engine shipped to my mechanic and he will do the swap. I also have an issue with the 4x4 not disengaging. That is a pull off solenoid under the hood. There is a TSB for that I need to get one.
Modifications to the truck already are Magnaflow high flow cats, Summit 3" cat back system with magnaflow reasonably quiet muffler. I was going for power, not noise... 2.5" Rancho lift with Moog HD coils, "California" fender trim, 17x9 rims 35x12.50 Hercules Trail Digger MTs, don]'t ever do those again! Go Rhino winch mount and Engo E9000 winch. Plus an Airraid CAI and XCal2 tuner. Tires need to be replaced as well. Probably drop back down to 285/70R17 BFGoodrich ATs...
I have a 300w solar suitcase setup, and an Econoline van cab/chassis battery box and mount that mounts UNDER the cab of the truck. So I will have a house battery and an engine battery.
I already have an Alpicool 60l LG compressor fridge that I am running in. So far so good.
Bed will be a 6" thick memory foam tri fold twin. Don't recall the MFG, but it is actually REAL twin not the narrow twins that are so common in tri folds...
The build out of the interior will have cabinets on both sides of the bed. The larger of the cabs on the passenger side so I can haul my water over there.
I have to go to my BILs funeral here shortly, his stupid a** was so busted up about his sister, he forgot about his diabetes and went on an alcohol fueled bender which did NOT end well for him...
II will get the weather seals in and the camper shell clamped down, then start scrubbing the inside and outside of both the camper shell AND truck bed. I need to make places to mount power outlets, reinforcements for an awning etc...
More pics to come.
Some background.
More pics to come.
