My friends wife let him come out and play again yesterday and we got quite a bit done! An extra pair of competent hands is always a huge help. We started by rough cutting the 3/16" plywood skins for the inside face of each side wall. Then using a 6" foam roller we spread glue over one section at a time and brad nailed the panels into place.
After letting the glue set up for a short time we took the router and trimmed out the door openings and around the edges.
Then we attached the side walls to the frame using (4) 2" carriage bolts for each side. I also through a couple 2-1/2" deck screws into the floor framing to draw the walls in tight in a couple places. Then double-checked that the angles at the front were correct.
After dinner I got to work on the lower bulkhead. Its essentially two rectangular frames that get skinned on each side. The void in the middle is a wire chase. The cabin-side is skinned in the picture, but the galley-side skin will have to wait to be attached until the galley shelf is installed. That way I can keep all the pocket holes hidden.
A little blurry, bit this the interior view. The 1x3 laid flat that resembles a small shelf is actually the bottom of a horizontal wire chase. You can also kind of see the rectangular cutout panel in the floor, at the base of the bulkhead, which gives access to the vertical wire chase.
I'll build some removable panels for the openings, but the openings serve a couple purposes: doggy door, air-conditioner location (only when needed), and i'll be able to slide my 10x10 canopy through there for transport.
Hope to get a little more done today!
