as w/ all my toys i carry the tools i would use to address anything i am capable of dealing with on the road(away frum the barn)
i get my roll around stool and a full set of tools and go around each new toy when i get it listing on a yellow pad what tools are needed to perform ... addressing any potential issue i can imagine
sometymes i find i can change certain fasteners out so more of them all use the same tools
example ... i change out phillips head screws for allen heads which saves space and weight
i've been guilty to cutting wrenches and welding the open end of one size to the box end of another size so 2 wrenches can handle both the head and nut for 2 sizes of bolts
as mentioned above i can also do a bearing replacement on the side of the road
the kit is made frum the list
each toy gets it's own set of toy specific tools instead of trying to remember what to pack each tyme i switch toys
sockets needed for particular applications are usually 3/8' drive except for the smallest one which is a 1/4" drive
a long 1/4" drive T-handle and long extension are my driver instead of a ratchet for each size
a 1/4" > 3/8" adapter is used for the larger sockets and they will slip onto the extension for carry using the adapter for a keeper and carrying the smallest socket on the T-handle
toy specific tools live in the leg of an old pair of jeans w/ a long flap to pour them out on
in my TV kit i carry a Klein 10/1 screw driver that has flat n phillips along w/ square and torx drivers and 3 different sizes of nut drivers all in one very good quality product
Klein has different combinations and they also sell replacement driver bits
when hauling bicycles a/o motorcycles along w/ the travel trailer i carry tyre repair/patching equipment
a plug kit for tubeless and cold patch for tube type and a small comprssor
the one i like is a Campbell/Hausfield w/ a small tank under it and a coiled hose w/ quick disconnects for both shrader valves and a blow gun for cleaning coils and other dusty funky situations
if hauling 2-wheelers goto HF and get one of their long combination wrenches for each axle nut size you have along
cut the open end off and grind the cut end into a tyre spoon
that's for starters
BON VOYAGE
sw
