ultra lightweight trailer chassis concept
kennyrayandersen
Senior Member
Joined
Apr 29, 2007
Posts
1,750
This build (design exercise really, since it will be awhile before I can get to the actual build) will be done in two threads -- one for the teardrop and one for the chassis. The teardrop thread is here: https://www.tnttt.com/viewtopic.php?f=27&t=75601. In order to lower the overall weight of the build, it became apparent that none of the commercially available trailers would work due to the weight. Furthermore, bolt-together trailers will generally be heavier than one that is designed and purpose-built. This chassis will cover what is necessary to size a trailer chassis with a couple of caveats: 1) the teardrop body will be designed as a mostly self-supporting structure 2) the sizing assumes that the trailer is not poorly loaded, or overloaded. I'll discuss the options, and design choices, and explain the fundamentals of how the chassis sizing can be done by anyone who can follow the math and punch the numbers into their calculator. With patience, I don't think it is terribly difficult once it's laid out and I will be happy to answer questions. I will also touch briefly on fatigue (that won't be too deep as I'm not a fatigue specialist).
General trailer layout:
Most trailers are very overbuilt and don't consider the strength brought to the table by the teardrop cabin. Therefore much of the trailer chassis is just along for the ride -- adding weight, but not doing much of anything -- I'm gonna throw that junk away! The walls of the cabin are extremely stiff -- far stiffer even than the steal frame and we're going to take advantage of that. The overall layout will take into account the stiffness of the cabin, which means that the trailer chassis itself can be greatly reduced! You might even call it a reduced chassis or a partial chassis. It's just enough to support the the load introduction from the chassis to the cabin. The cabin will take care of the cabin (we don't need no stinking chassis! (not entirely true, but you get the point!))
The chassis width is 48 inches
Aluminum is 1/3 the weight of steel. I've used steel in airplanes, but when we use it in aerospace -- it's the good stuff. I cant afford the good stuff, so lets compare hobbyist grade aluminum to mild steel:
Steel - mild steel
Yield stress = 47.7 Ksi
Ultimate stress = 58 Ksi
Aluminum 6061-T6
Yield stress = Fcy = 37 Ksi
Ultimate stress = Ftu = 41 Ksi
Aluminum 6061-T4 (T6 post weld and age hardened is approximately T4)
Yield stress = Fcy = 16 Ksi
Ultimate stress = Ftu = 26 Ksi
So, although there are stronger aluminums (more expensive), and stronger steels (more expensive), at the bottom we see that the mild steel is a little stronger than the common 6061-T6 aluminum that the consumer is likely to have access to; however, it is 3 times the weight! A quick check at On-line Metals shows for a 6 ft piece of .065 1x2 steel the price is $36.71, while the same 6061-T6 aluminum in .062 wall is 32.50! So, at the same price, 1/3 the weight and nearly the same strength - let's investigate the aluminum.
I like this design. I'll be watching closely.
I want to create an ultralight teardrop that my EV can pull without seriously limiting its range. I have an old boat trailer (4' wide between wheels/fenders) and I was going to convert that but maybe I'll use its axle and go this route instead. Anxious to hear from the engineer types to see the precautions of a chassis like this.
Tim
Yes. The walls are like trusses and a lot of stiffness. That's why I think cutting of the rails of those trailers - while weakening it as a utility trailer - is fine with a teardrop.
And your trailer design is like the Pico Light (?) that used to be in the design guide. I've admired it's design elegance.
This should be a great build thread!
I watched a You-tuber yesterday discussing people modifying utility trailers and how it weakened them and I was disappointed that he couldn't understand the concept that the vertical walls, if attached, become the structure! Yes, the layout is very much like the Pico, but with Andrew gone (I assume he passed), and virtually none of those links working; and with no math behind any of the pictures, a general layout isn't much good because you don't know whether it will work in your particular application. I hope to show how to arrive at the sizing and discuss material and frame section choices.
I am not a structural engineer.... However, I'd like to suggest the addition of a length of angle iron to catch the front of the cabin and spread out the point loading. This will improve the bearing of the cabin on the two pieces of tongue. It will protect the integrity of that junction.
:thinking:
I'll be watching your design with great interest. :D
Tim
I think there is a real need to build lightweight and EVs is certainly an area with huge repercussions for tow weight. I recently watched a video of a Ford F-150 Lightning doing some light (maybe medium - 6000 lb) towing and it made me think that they shouldn't have bothered - they got less than 100 miles! Keeping the weight down, and the teardrop in the aerodynamic shadow of the tow vehicle (teardrop should be both narrower and as short or shorter than the tow vehicle) would go a LONG way in making towing a teardrop behind an EV practical.
:thinking:
Ah, broughhaha, haha! The trailer floor will have the very cross-member of which you speak! So, part of this exercise will be to eliminate the redundancy between the trailer and the cabin! :twisted: But this is actually a very good suggestion. However, after having run the numbers a bit, I'm pretty confident that the trailer can be made from aluminum and we wouldn't want to put any welds, or unnecessary holes in the trailer frame, so attaching that member on the trailer would pose some design challenges. With aluminum -- especially heat-treated aluminum -- we don't want to introduce any unnecessary stress concentrations (Kt) because it would cause fatigue issues, or welds in critical areas as you lose the heat-treated strength in the weld zone. Calculations to follow!
Numbers:
First we have to establish the design/analysis criteria, and the environment
Typically on-road (we'll hereafter refer to this as over the road (OTR)) vehicles and trailers are designed to 3gs and off-road (OR) vehicles and trailers are designed to 5gs - we will consider those Design Limit loads (DLL) (maximum loads the structure would ever see during it's lifetime). We also generally use an ultimate load factor of 1.5 to arrive at the Design Ultimate Load (DUL). The criteria is no yield at DLL, and no failure at DUL.
Let's also make some assumptions about the teardrop and introduce some dimensions based on the design goals. For now -- let's set the weight at no more than 300 lb (and hopefully we will be under that significantly). The 1963 FIAT 500 is 52 in. wide, but the Smart fortwo is 60 inches wide, so in order to clear the fortwo there should be somewhere in the neighborhood of 30 inches of clearance. so, the distance we need is from the ball (the load to the tongue is introduced at the ball) to where the cabin intersects the trailer. If your cabin curves aft at the front bottom, it's critical to use the intersection of cabin and frame rather than the distance to the from of the cabin. In my cabin design I brought the front straight down for two reasons 1) it makes the front of the cabin stiffer and stronger because there is a large vertical section to react the loads, and 2) it reduces the moment arm in the tongue of the frame, and so reduces the stress in the frame. That might not be a showstopper, but in any case the right dimension needs to be used in the calculations.
First let's pick a material. Since we are shooting for lightweight, let's pick aluminum, and the most readily available and at a decent price is 6061-T6. Furthermore, 6061 is a weldable aluminum alloy. The properties are:
E, Young's Modulus = 9.9E6
Fcy = compression yield = 37 Ksi
Ftu = Ultimate allowable tension stress = 41 Ksi
For weld zones (we'll talk about those later) the material becomes annealed, but 6061 quickly age-hardens over a few weeks and months to the T4 condition. So, for heat affected areas we will use the T4 properties:
Fcy = compression yield = 16 Ksi
Ftu = Ultimate allowable tension stress = 26 Ksi
(When we look at the difference in properties between the T6 and T4 conditions, it tells us is that we don't want to do ANY welding in a stress critical area!)
Since we set the weight of the teardrop at 300 lb, we can use a percentage of that weight to apply to the coupler at the ball .I think a fair target would be 15% of the total trailer weight, but lets be on the safe side and use 20%. We use the letter P for load (because we use L for something else!)
P = .20 * 300 lb = 60 lb
Now we calculate the maximum moment in the tongue area which is where the front of the cabin meets the frame
L = 30 inches (tongue length from ball to cabin)
M = L * P = 60 lb * 30 inches = 1800 in-lbs
Inertia is the beams resistance to bending. Inertia for a rectangular section is:
I = 1/12bh^3 -- that is for a solid section where b is the width and h is the height.
For a hollow section we can calculate what it would be for a solid section and then subtract the hole from it. Our equation then becomes:
I = 1/12(b_outer * h_outer^3 - b_inner * h_inner^3)
Alternately sometimes you can find I listed for a particular beam section - the units are in^4
The astute observer will see that the h term is cubed! So, a 1x2 section, for instance, is much stronger standing up than lying down! We'll stand ours up!
Let's start by using a 1x2 aluminum section with a .062 wall, standing vertically!
I = 1/12 ((1)*(2)^3 - (.875)*(1.875)^3) and since we have 2 frame members the equation becomes:
I = 1/6 ((1)*(2)^3 - (.875)*(1.875)^3) = .372 in^4
The bending stress is: F_b = Mc/I where M is the Moment, c is the distance from the section centroid to the outer fiber (for symmetric sections it is just 1/2 the height), and I is the Inertia
The original moment was 1800 in-lb, but that is at 1g. For OTR we'll use 3g, and for OR we'll use 5g
M_OTR = 1800 in-lb *3 - 5400 in-lb
M_OR = 1800 in-lb *3 = 9000 in-lbs
plugging in the numbers into the bending stress equation: fb = M*c/I
fb OTR = (5400 in-lb * 1in)/.372 in^4 = 14.5 Ksi
M.S. = margin of safety = F_allowable/f_actual - 1
M.S yield_OTR = 37 Ksi/14.5 Ksi - 1 = +1.55 (yield criteria is met - anything above +0.00 is OK)
Check for no failure at ultimate load
Ultimate f_bending = f_bending DLL * 1.5 = 14.5 * 1.5 = 21.8 Ksi
M.S. ult otr = 41 Ksi/21.8 Ksi = +.88 (ultimate criteria is met)
(note that for ductile materials that have been heat-treated, the ultimate stress check is usually the critical one, but with annealed 6061 the yield check is critical)
Lets check whether the OR loading is OK
f_b OR = 9000 in lb * 1/.372 = 24.2 Ksi Limit, 36.3 Ultimate
M.S. OR Lim = 37/24.2 - 1 = +.52 (Yield check is satidfied)
M.S OR Ult = 41/36.3 - 1 = +.13 (Ultimate check is satisfied)
So, for static loading, over-the-road or off-road, the strength requirement is met.
We're talking about aluminum here though, right? How about fatigue?
When aluminum is working hard enough there is damage being done with every load cycle. The higher the stress, the more damage is done with every cycle. If the stress is very high, you might only get a few cycles before failure; however, at low stress there is little or no damage being done. The key to a long fatigue life is to limit the operating stress to one low enough that you aren't doing significant damage when it is repeatedly loaded. For 6061-T6 aluminum the endurance limit is 14000 psi, which assumes: 500,000,000 cycles completely reversed stress (this assumes an stress ratio of -1 i.e. fully reversible). Because I g-loading, OTR or OR, is almost exactly in one direction our load does not fully reverse, and that makes a huge different. We can assume that our load gets applied, and then never goes below zero - that gives us a stress ratio of zero (non-reversing load).
Lets look at the fatigue endurance curves
The plus symbol is the curve were looking at (stress ratio of zero) and the endurance limit is just a bit above 20 KSI for repeated loading for which stresses below that will result in an infinite life. So, we'll use that as our stress to stay under for Limit loading. This is a bit conservative and we are not realizing limit stress every time the frame is loaded; but, if we set the stress this low at limit load, then we should be way OK for fatigue. Note that this assumes that we haven introduced any holes or welds in a stress critical area.
Let's look at our limit stresses again:
fb OTR = 14.5 Ksi Limit (below 20 Ksi, so it looks like fatigue won't be a problem unless we screw up some design feature!)
fb OR = 24.2 Ksi Limit (this is above 20 KSI, so it doesn't meet the fatigue cut-off for a infinite life)
Therefore, so far, the 1x2x.062 rectangular section should work for the frame (we will do other checks to confirm) in the OTR case, but wouldn't be acceptable for off-roading.
So, what does this tell us? For a OTR design the aluminum .062 wall section should work fine, but for off-road this section wouldn't be recommended. The designer of an off-road version would then have a choice here: 1) use aluminum, but change the wall thickness to .12 in., 2) change the .062 wall aluminum section to 2x2, or 3) use a 1x2 .062 section made from steel, which would carry a smaller weight penalty compared to an aluminum section that now grows to the next size up and doesn't have the same fatigue considerations.
This concludes the initial check. More checks to follow.
Strength Checks continuing:
Weld areas have lower allowables, so the next check would be aft of the ball where the A-frame comes together and is welded. assume T6 heat treat is lost and the material has annealed and been age-hardened to the T4 condition.
(Properties listed in first post)
Since the moment is linear we can ratio the stress. check at 16 in. from the ball
16/x=30/14.5
Fb@ 16 in = x = (16*14.5)/30 = 7.7 Ksai Limit, 11.6 ultimate
Use properties from 6061-T4
M.S. Limit = 16/7.7 -1 = +1.08 (as stated earlier the yield margin is critical in the weld area) (OK for Limit)
M.S. Ultimate = 26/11.6 -1 = +1.24 (OK for ultimate loading)
The endurance limit for aluminum is approximately 1/2 the ultimate tensile strength, so the fatigue would be OK for here as well
Let's check to see if the attachment of the coupler is OK
sorry for the unsophisticated art...
The fastener going through the side of the frame section are 3/8 in dia
When we are calculating the reactions on a beam, we typically sum the forces which must equal zero (else it would be flinging in space), and we can sum the moments, which also must be equal to zero (else flinging)
Going back to our ball load, it was 60 lb at 1g
Sum M = 0
Moments that make clockwise are negative, and moments that are CCW positive. For convenience we will sum the moments about R2 (refer to diagram)
P * 7.5 in - R1 * 2.25 in = 0
Solving for R1 (reaction at first bolt) = 5.25*60/2.25 = -200 lb
At limit load (3g) we get -600 lb
Note that the bolt goes all the way through the section and the bolt is in double shear so that each side of the frame section is reacting 1/2 of the load; therefore:
P_bolt_shear = -600 lb / 2 = -300 lb This is a trivial load for a 3/8 inch fastener
We should also check the second bolt (although I already know it will be less critical)
This time we will use summation of forces = 0
60 - 200 + R2 = 0
Solve for R2
R2 = 200 - 60 = 140 lb @1g
Since this bolt load is less than the first bot at R1 is it OK by comparison
Let's check bearing stress in the aluminum
Area_bearing = t * D where t = material thickness and D = bolt diameter
A_br = .062 * .375 = .0232 in^2
f_br_yield = 300 lb / .0232 in^2 = 12.9 Ksi
f_br_ult = P/A_br = 450 lb / .0232 in^2 = 19.4 Ksi
F_br_yield = 56 Ksi
Fbr_ult = 88 Ksi
M.S. br ult = 88 / 19.4 -1 = +high
Fbr_limit = 88 Ksi
M.S. br linit = 56 / 12.9 -1 = +high
Note these fasteners go through the frame section near the middle (close to the centroid) where the stress is very low so that it doesn't affect the margin we already calculated for the frame section
Coupler attachment is OK
P
Tim
This trailer design is not new - there's some OLD posts around here with the simple A style chassis.
That pretty much covers the loads expected whilst going down the road. There is one other condition that I considered and that what about when both people are in the cabin? The critical condition is likely when they are both entering into the cabin at the door, and let's say they plop them selves down in the doorways simultaneously.
Assumptions:
2- people @ 200 lb each
1g plus 1.5 dynamic magnification factor
We need to calculate the load on the ball
The 2 reaction points are at the ball and at the wheels (see figure above)
Summing the moments as we did before about point R2
-R1 * 78 in + 400 lb * (78 in - 54 in) = 0
Solve for R1 = 400*24/78 = 123 lb
plus we have already the static load from the trailer itself (remember that 60 lb load on the ball?)
P_ball_total = 123 lb + 60 lb = 183 lb (this is at 1 g)
Moment at the cabin and trailer frame intersect = 183 lb * 30 in = 5490 in-lb
Fb_lim = 5490*1/.372 = 14.8 Ksi
Adding the dynamic magnification factor (this is really quire conservative as it requires both people to plop particularly hard at the same time)
Fb_lim_final = 14.8 *1.5 = 22.1 Ksi
M.S. Lim = 37/22.1 - 1 = +.67 (Limit check is OK)
M.S Ult = 41/(22.1*1.5) -1 = +.23 (Ultimate check is OK)
This would also lower the coupler margin just a bit, but because those margins are high it's not an issue
People loads are OK
Tim
Yes, I already addressed that. It's very similar to the Pico frame, but there no numbers or analysis to support the sizing so this is about figuring our how to size the frame (any frame really). The principles would apply to any frame -- not just an A-frame. I chose the A-frame because I believe that to be the lightest weight configuration and I need a very light teardrop.
Just wondering if instead of an A frame it was a U frame. Possibly supporting two to three feet of the front of the cabin.
More complicated obviously requiring some bending.
U's, not being straight create additional torsional moments when loaded. It might well work, but there is a cross member in the floor, shown on the cabin thread (as opposed to the frame thread). And I think you are right about the forming challenges. I think, in the end, the cabin is still supported at 3 points -- the ball, and each of the 2 wheels. If the cabin is self-supporting and has a good attachment to the frame, I think it should work out OK. The original layout, by Andrew for the Pico also had the A-frame configuration, and I incidentally just spotted a teardrop that is currently being manufactured with an A-frame trailer. I haven't show the weight calculations, but right now at .062 wall the frame weight (not including suspension or coupler is just over 11 lb. If you go up to .125 in wall thickness it's still only 17.4 lb! With the torsion 1/2 axles this should be a very light trailer!
I agree the A works fine, especially with plumb cabin front. The floor if built right won't flex and cabin face will doubly assure that. It does need to be anchored.
Think unibody versus body on frame. Or airplane versus house.
Very exciting.
Tim
I've been admiring the Pico chassis since I started my first teardrop in 2016. I even researched doing the A-frame out of lumber which doesn't seem like a great idea. :thinking:
Very exciting.
Qbill, are you referring to a floor built with a proper torsion box design? For instance with ply and laminated ply sticks of ripped ply like Glulam? That seems like it would be an easy, DIY structure. A bit more labor involved in the construction but very strong and durable.
I'm thinking DIY glulam of appropriate dimensions, maybe 1 1/2" square, sandwiched between 3/8 plywood and properly sealed from road splash. Does that make sense?
Tim
Very exciting.
Tim
The floor can handle some torsion, although the torsion loads aren't that high (I don't think), but the floor isn't very tall, so the torsion really wants to go into the cabin (think convertible -- even though there ain't much to a hard top, the overall structure is WAY stiffer than the convertible version of the same car). Torsion is reacted by the area reacting the torsion. In a wing it's the area you get when you take a section through the wing xz plane where z is aft z is up and you are using the right hand rule (x cross y = z). That area pretty much looks like a wing rib, and that's the closed area that reacts the torsion. If you take a section cut trough the floor you don't get much area because the floor is only a couple inches deep, whereas if you take a cut through the cabin its' something like 4 ft x 4 ft or more! So, cabin want to react the torsion. At the door cutouts, if they are large, the torsion load would be split between the floor and roof, and differential bending between the floor and roof. In the end -- it's stiffer than it looks.
The A-frame is probably the lightest way to build a chassis as there isn't much that's redundant. The Harbor freight and utility trailers have a LOT of structure that isn't really loaded up much, so in the end, you carry all that excess around. Wood is doable with a bit of engineering, but you have to ask yourself why? White oak is good for 10-12 Ksi in it's grain direction if I remember right, but wood isn't great in bearing, it's going to probably weigh a bit more, and the chassis is exposed to the worst of it weather-wise. If you want the woody look it would probably be better to keep it to the cabin and keep the chassis frame metal of some kind, though it certainly is possible!
Very exciting.
Tim
They were called stressed skin panels in my classes but torsion box may be same. The APA (American Plywood Association) has tech sheets on it. I agree whole cabin is important but each "side" has to be fairly stiff.
Whether the skins - and I presume plywood for teardrops is most practical - are separated by rigid members, honeycomb, foam, or other - is secondary. SIPs are just another variation.
