ohbugger":3p3sland said:yup, it is very similar to some actual car audio sound deadener I have. The sound deadener is supposed to be butyl rubber or something whereas this is asphalt, but the effect is the same. Black sticky stuff on a roll.
I will note that there were a few times that I wanted to adjust it slightly after laying it down and that wasn't happening... it was definitely stuck. The only way to move it would have destroyed it.
cuyeda":1i9pxtqy said:ohbugger":1i9pxtqy said:yup, it is very similar to some actual car audio sound deadener I have. The sound deadener is supposed to be butyl rubber or something whereas this is asphalt, but the effect is the same. Black sticky stuff on a roll.
Sound deadener for the car! Marvelous! Can anyone tell us if this product gives off any asphalt odor. I wonder if it heats up a little with car mufflers under a floor pan if the product would be prone to an asphalt smell? I have a 65 Mustang 2+2 project, but that real stuff cost quite a bit more. Don't want to hijack the thread, just a quick comment.
This stuff sounds like a really good Ideal....Does it cure so that it feels dry when you touch it?I used the paint on in a can on the first floor I built because everyone on here was using it.It never dryed or cured and the smell never went away.I threw that floor away and painted my new floor and covered it with a heavy piece of plactic.I am starting a new build and was looking for some Ideals. thanksJeepThing":aoz9xj2x said:I actually used this stuff on my build, it sticks very well, ( note in the heat of summer it will get very soft) not a prob if you don,t touch it just messy as i used it on all corners where wall met floor or roof as well as around all the doors and windows. No water is going to get at the wood on my trailer, well worth the small cost. extra protection is a good thing. Like the rest of my trailer it's "Over built"
jimqpublic":25h912pn said:After replacing some rotted OSB on the floor of my A-frame trailer last year- and finding more this year...
I think completely waterproofing both the bottom and top of the floor is a recipe for disaster. Any water that gets in can't get out. I live in southern California- we get more dew than rain. Unfortunately a tiny bit of dew dripping down every day was wicking around a molding and seeping into the edge of the flooring. Vinyl on top, poly sheeting on the bottom- No where for the moisture to get out.
I suggest latex paint to coat the bottom. Very water resistant, but vapor semi-permeable allowing it to dry out over time.
Also watch out for that bottom trim molding!
