Jwh92020
Senior Member
Anyone used .019 aluminum trim coil for a roof? It would be laid over a 1/4" deck. I'm building a camper for a guy who wants to use the coil. He understands about the seams and is willing to have them.
Would you like to regenerate the title as well as the summary?
That might work on a vertical or sloped surface with enough overlap at the seams. I don't think butt joints or even overlaps on a horizontal surface like the roof would stay leakfree very long.Anyone used .019 aluminum trim coil for a roof? It would be laid over a 1/4" deck. I'm building a camper for a guy who wants to use the coil. He understands about the seams and is willing to have them.
He's agreed to 26 ga roof metal - flat sheets, no ribs. He'll be much happier a year from now.My thought is do it right or do it again. He may save a few bucks now but how much is that savings worth in a few years if it starts to leak or gets punctured?
What I did with mine is spray proper catalyzed bedliner on my squaredrop, all 6 sides.
I'm thinking about using it on my regular camper roof also since it is one monolithic piece once cured, is designed to take abuse, is UV stable, will conform to any shape/angle, can be made as thick as you want and the thickness can be varied, bonds like mad with proper prep, many different color choices with some manufacturers and relatively easy to repair. But it needs a proper underlayment which your plywood would work...id go thicker than 1/4" personally.
Just a thought.
