Members debated the pros and cons of mounting a vent fan on the roof versus the side wall of a compact 4x8 squaredrop trailer. Several RVers emphasized that roof-mounted fans are more effective at venting hot air, as heat naturally rises, and allow for passive ventilation even when the fan is off. This setup also draws in fresh air from side windows, which many found beneficial for comfort and airflow. However, some members shared creative alternatives, such as using marine deck plates, boat...
More...
Members debated the pros and cons of mounting a vent fan on the roof versus the side wall of a compact 4x8 squaredrop trailer. Several RVers emphasized that roof-mounted fans are more effective at venting hot air, as heat naturally rises, and allow for passive ventilation even when the fan is off. This setup also draws in fresh air from side windows, which many found beneficial for comfort and airflow. However, some members shared creative alternatives, such as using marine deck plates, boat access ports, or steel side vents on the walls for rain-proof, low-profile, and durable ventilation—especially useful for those wanting to avoid roof penetrations for reasons like roof rack space or minimizing wind resistance.
A few RVers described successful side or floor vent installations, noting benefits like increased security, weather resistance, and the ability to leave vents open during storage. One member detailed a floor-exhaust system with a baffle to prevent water intrusion, highlighting the importance of make-up air for any venting approach. While most agreed that roof fans offer the best heat evacuation, side and floor vents were seen as viable for specific needs, especially in cooler climates or for those prioritizing stealth and durability.
