Walls up!
Lyle85213
New Member
Joined
Oct 20, 2025
Posts
6
Location
Mesa, AZ
I spent the weekend installing my walls and betting them square. I first cut a small hole where the doors go and using a c-clamp as an attachment point used a synch strap to pull the base of the wall together. I then made to temp crossover studs at 63" inches ( the width of the trailer ) at 3 points along the wall and made sure the width was uniform. I then attached another synch strap from the bottom of the starboard wall to the top of the port wall and made sure the wall was square. I then repeated for the other wall. Once I could see that both walls were square I attached a diagonal support from the wall to the block on the floor. As added support, I added to pieces of 67.25" pieces of scrap lumber and places in a X and the bulkhead between the galley and sleeping cabin. I then tied down the walls with 2" screws going through the 1" stud along the floor into the floor section of the trailer as well as along the outside plywood overhang.
Next steps, attach my two center formers over my temp cross studs and glue in my real cross studs along with right angle wood supports to keep the walls square. This is similar to the way I constructed the fuselage my HiMax aircraft.
Exciting, that was a big moment for me. Started to see the vision take form.
That's always a great corner ot turn. Out of curiosity, why not sheath the interior before mounting the walls?
My reasoning is I want to keep this trailer very modular. I'm mounting the walls to the floor using 2" screws. By, keeping the interior sheath off at them point gives me easy access to the stud that runs the length of the floor for the screws. I'm also aware that this trailer will need maintenance and inspections. By allowing the cabin to be removed, I can easily see defects such as cracks and mold or rot. Later, I'll add the insulation/electrical and then screw in plywood panels again keeping it so I can easily inspect/maintain the insulation/electrical. The galley will also be module sliding out as an entire unit that can be replace/upgraded/maintained as needed. Just as an airplane is taken apart for it's annual inspection that FAA requires by law ( remember that I'm building this using techniques I learned building my HiMax airplane ), so I also want to be able to do annual inspections of my teardrop trailer
New posts
