Water crossings
Steve F-TNT
Senior Member
Joined
Feb 2, 2007
Posts
489
Is there anything special I need to do when building the teardrop to make it more suitable for water crossings? I'm thinking of some sort of plate at the front of the trailer where the body mounts that is angled back like the front of a flat bottom boat. I'd hope this would create a small bow wave and push the water under and around the trailer, but I dont want it to start floating :shock:
My Jeep does not see water crossings every trip but one of my favourite spots has several fords (7) to go through and then a river crossing which can be anywhere from half way up my wheels to just over the front bumper. I'm not sure what that actually is in real measurements so I'll post a pic of the Jeep for you to get an idea.
These are actually the wheels and tyres it will be running on the trailer as I have larger ones going on the jeep in about a week
Cheers
Steve, I guess it all depends on what the final weight of your build will be. Mine came in at 600kg(1300lbs for you merkans) and I have not worried about any special treatment re water crossings. I'd be more concerned with sealing it rather than worrying about it floating. Floating would only be a concern if it came unhitched. Have a look at this site http://outbackteardrop.com/ Larry's done a great job on this offroader. It's where I got my idea from.
Cheers
Paul :thumbsup:
Floating may be bad. Figure the current swinging it around and hitting the car or pulling it down stream :shock:
Gerdo":pns7o5w9 said:
How deep are you talking? How about building it so the bottom stays out of the water.
Depth could be anything up to 3' (I've had water over the bonnet and in the drivers window but wouldn't tow through that). The Jeep punches a hole and creates a bow wave as it goes so I would hope that directly behind it it would be shallower. I plan to have the floor pretty high if I can, possibly the same height as the jeep floor but that's getting pretty tall, about 23" (might need a step as well for my wife). I think the best option is also some sort of plate, like the plate under the front of the Jeep, which will help create a bow wave and push the water out and around the trailer. Of course door seals are going to be pretty important as well, I might actually use some wet floor sealer on the inside and up the walls a little, say the height of the mattress and then store the mattress prior to any deepish crossings, then I could just wipe out any water.
Cheers
I'd be real careful with what your thinking re the height. I've seen normal trailer type camper trailers doing Cape York just after the wet. Keep on planning before you decide on final height. Even the T-Van is not as high as you are talking.
Cheers
Paul :thumbsup:
Cheers
Paul :thumbsup:
Agreed, I really do think the same height as the jeep is too tall. Maybe I'll just sit it at a lower,safer height and pick my water crossings a bit better ;)
Cheers
Having the floor 3' off the ground is probably too high. I see what you mean now.
Now back to your question. If you have your lower front edge either rounded (Cub) or angular (Grasshopper) it will want to ride up on the water and push water under. If you have the front side leading edges rounded or angular it will want to push the water to the sides. Yopu will want to realy seal any points where walls meet the floor.
You will want to rethink hatch construction. Maybe have it only open from a midpoint, up keeping the bottom sealed with the floor and walls. You can have storage below the counter top, access from a lift up counter top/panels.
You can have, at least the lower portion, of the exterior sprayed with Line-X (spray on truck bed liner)
As far as your floating predicament. I don't build boats but it sounds like your going to build one. I'm guessing that it will float. The problem that I see is that it won't have a bow. It may want to roll to one side.
If you make your doors with all rounded "corners" you will be able to seal them better. I have 90* corners on my doors and I had to cut my weatherstrip and put a piece on each side. On rounded corners you can have a continious piece around the whole door (have the start and stop ends toward the top on the rear side). In the corners where the seal meets is where I have gaps, potential leaks.
I'm thinking now I can do what I do with the front of the Jeep on deep crossings, put on a blind. Basically have attachment points on the frame for a tarp of some sort and put it over the front of the TD and up the sides past the door as well as under the frame. As long as I keep moving water ingress is not so much a problem with a blind and most crossings are fairly short. I also like the idea of the curved door to allow a continual seal all the way around.
Cheers
Floating may not be a bad idea,, the military 1/4 ton trailers floated, with 500# in them too. As long as you have a good coupler the trailer should stay behind well, as long as its not heavily flowing water, but then its not good to cross flowing water straight but to go more upstream as you cross. The floating would keep the trailer axle up away from hanging up on rocks.
Steve C
I agree that floating isn't a bad thing as long as the water is really fast. i have pulled my M101 1/4 ton trailer thru fairly deep crossing behind my landcruiser without it swinging around. I am starting to build my first tear, and it will be on 35" tires and be about as high as my landcruiser. I am hoping it will float, but it will still be around 800#'s
Ryan
[/url]
Before anyone asks, I have put my extensive training as a naval architect to good use and divided one number by two others (it was hard, but I stuck at it....) and come up with the following:
An 8ft x 4ft trailer weighing 1000 pounds will float at a draught (depth) of 6.0in.
In practice the trailer may float slightly higher than this as the tyres will contribute quite a bit of buoyancy before the trailer body ever reaches the water - a pair of 205/75-15 tyres will carry about 100 pounds when immersed halfway (ie, 200 pounds per pair fully immersed).
Andrew
Andrew,,
Very impressive,, very impressive,,
There used to be a vidio on the net somewhere of a guy using the m416 as a boat, had a 9hp outboard tooling around a lake.. If I find it I'll post a link.
Steve C
Just a thought but what about making a combing around your door so that you could place a water proofed spray skirt aournd the exterior of your door opening. It would be similar to a spray skirt like that found on white water kayaks. They are real easy to make and while not 100 water proof they will keep 99% of the water out. should work rather well.
Another idea is to build the camper off frame with a flat bottom and to fiberglass the bottom and wrap it up the sides a few feet to keep the water out. Or if you weld buy some alum and make the floor out of if and weld some side panels to the floor panel once again creating a tub style structure. Just make sure your welds are good.
Jon
Piano hinges leak. They leak even worse when dragged through water. (same goes for speeding down the interstate in a rainstorm) You can cover them with neoprene, or Naugahyde, or You might consider a gear hinge for your TD cabin doors SoCalTearDrops sells those. Not cheap at $20 a foot, but my neighbor is still happy with it. http://socalteardrops.com/hinge.html
The bottom edge of our TD cabin doors are about 6" up from the bottom of the sides, (the sides overhang the frame, which I might not do again, actually) so the water has to get that much higher before it gets inside the cabin. In my experience, water dries out, so even if we get a little wet, we're usually in a desert anyway. If we traveled to more humid areas, I might think about it differently.
I used the same aluminum on the bottom of the TD as we used on the sides. The idea being to try & protect it the bottom, not just leave it as bare wood. I'm going to go around the bottom & reseal it with silicone too.
As Andrew says, you will float in around 6". Water weighs 62#/cubic foot. Given a foot print of 4'x8', gives you 32 square feet. If you have a larger foot print, you will float in less water.
32 cubic feet of water weighs weighs around 2,000 pounds. To displace a 1200# trailer only requires the trailer be in a bit over 6" of water.
Then you have the doors and galley as leak points..... and any through bolts.
So, build high..... or tape the doors and have a drag rope to hold onto to keep it from swinging, but if the current is strong, one person won't keep it straight. Moving water is very powerful.
Looking through this thread this mourning, I got to thinking , How would I build if I had to plan on water crossings? well that had my mind here all day. but the solution I came up with is
Estimate the overall weight of tear and contents in a completed state.
Plan on building on top of the frame
Do the math, using the formula in above posts to figure out the displacement and how deep it would be in the water at the fully loaded weight. I wouldn't include the buoyancy of the tires let theme give you an extra (if any) margin of safety
Use the depth from above and add a sufficient amount (something you are comfortable with) as your "water line" build up this line as if you were building a boat, I.E. seal everything, fiberglass not only the seams but the entire box up to the water line at the least
Build the openings (doors and hatch) above the water line.
keep the center of gravity as low as possible to avoid it rolling over in the current and turning into a submarine.
If with the waterline and the height of the rig it is hard to get into I would consider a fold out porch off of the frame (legs to ground double as a ladder) or putting the door in the front over the tong and making a porch there
Of course these are just some things that I had to get out of my head feel free to toss theme back and/or use theme. If I start another as a waaaaaaaaaay down the road project I am going to look closely at this
Might also consider using fiberglass tape on all and any seams under the tear also. That will keep most of the water out of your seams and out of the end grain of your wood. If its good enough for wooden boats, it has to be good enough for the occasional water crossing. Having been in the navy, there are a few ideas floating around in my head about sealing a door. :) Once you've caught your forehead and shins on a few hatches, you remember how they were built.
Steve,
I love both your TD and your XJ. Being an XJ guy myself, I appreciate such beauty.
Have you taken your TD through any water crossings yet? Did you do any special water-proofing for your TD?
New posts
