It is interesting to note the different ideas here.
The foam you mention being used in a wing is a pretty good example. but the foam has -0- structural strength. it is the forming of the complete panel, with the adjoining attachment of the edge of the skins that makes the strength. Any of the mentioned foams have little or no strength, it is when they are joined as a unit they have strength. This is unless you have the $$ to buy some carbon foam. Not me!
To make the point, you could (if you had enough money and time) make a camper wall (or the entire camper) out of JUST fiberglass and resin. But it would be HEAVY. The flex of the walls and floor necessitate the need to have a stiff construction. Thus the fiberglass would have to be about 3/16 or 1/4" thick all over. It would still need stiffeners, all over to make the walls and roof not flex. To fill you in, in early fiberglass boat building, they built them the same thickness as the wooden boats they were copying. some hulls were 1" or more thick. It was soon found out that that was WAY overkill. Now we are just trying to make as light a wall as possible, using the cheapest stuff around. (At least I am!)
Or you could make a camper out of just Foam. No matter how much liguid nails you use, the foam box will fail. Yes, it will work, and function until...... a bump, a thump, or a gust of wind and poof its all gone.
So this is about how to meld the two together. Someone else mentioned that delamination is caused by exposure to the sun. That is true to an extent, but this is only important when you are trying to KEEP the core attached to the skin. In an ultra lightweight construction the core adhesion is relatively UNimportant. This is what is being lost in these conversations. This switching between these two construction types seems to be getting people confused.
[/img]
Sorry about the cheesy paint thing!
