Weight savings with a Foamie build vs plywood?
BrianInVA
Advanced Member
Joined
Jan 26, 2022
Posts
92
Quick question - I’ve been searching and I’m finding it nearly impossible to locate a “frugal” (read cheap) source of xps foam. However, I’m finding cheap sources of plywood and various sizes of lumber all over Facebook Marketplace.
How much weight is saved with a Foamie camper build vs a plywood/wood small camper build? I hope to build a 6”x10’ vargo type “standy” camper similar to the image below. My tow vehicle weight limit is 1500lbs.
Consider plywood averages 57 lbs. per cubic foot , Foam is a LOT less .... :eek:
Regarding cost , a sheet of foam is still less than a sheet of 3/4" plywood ...around here ... :thinking:
Don't compromise to save a few hundred today. You won't miss the extra money spent a few years from now. You will regret having spent months working on a trailer that's heavier than it should have been because you wanted to save a few bucks.
A 4'x8'x2" piece of Corning XPS Formular 250 weighs 7.5lbs. As stated above a piece of OSB or Plywood in the 1/2" range is around 57lbs. Building a simple 4'x8' square drop body like I do would require 1 sheet of OSB 7/16" and 4 sheets of XPS 2". This would weigh 87lbs before canvasing and adding doors and windows. Now building the same body with just plywood or OSB would bring the weight to about 285lbs before canvasing and adding doors and windows. As you can see building with XPS is nearly 200lbs. lighter. Of course the bigger the build the more difference will be noticed.
My complete 4'x8' builds on a harbor freight trailer usually come in around 375lbs. The Harbor Freight trailer weighs 253lbs. Door, window and canvas/paint only adds about 35lbs.
Building with XPS also gives you the extra benefit of adding insulation into the build without adding even more weight or doing without insulation at all. Also, you don't have to worry about wood rotting.
If you build something similar to the camper in the photo using traditional methods, it will more than likely weigh well over your 1500 pound max.
And by the way, because of the frontal mass of that design, it'll have a lot of drag. In other words, for a small car, it'll be a beast to tow at anything above 50.
I don't mean to be the bearer of bad news.
:thinking:
:thinking:
My tow car is a 2009 Ford Crown Vic, a big old police interceptor sedan with a small v8. The towing capacity is limited to 1500lbs, but only due to its type of rear suspension. Ford trucks with the same motor and transmission had much higher towing capacity.
tony.latham":1fgkiyy0 said:
.........And by the way, because of the frontal mass of that design, it'll have a lot of drag. In other words, for a small car, it'll be a beast to tow at anything above 50.
:thinking:
That's going to be like towing a parachute....
A vardo has the advantage of standing room, taller doors, etc. which makes it easier to reconfigure the inside for sleeping, eating, sitting and cooking. So, if you don't plan to move it very far or very often, the design has definite advantages.
A LOT is going to depend on the specific species of wood the plywood is made from and how dry it is, but on average a 4x8 sheet of 3/4" plywood will weigh about 60lbs.
A 4x8 sheet of 1" XPS foam board insulation weighs 4.41 lbs. It would take close to 12 sheets of foam board to equal the weight of one sheet of plywood.
Plus your plywood will have zero insulation value
:thinking:
I’m going to make the front end similar to the FoamStream here on the forum, for better aerodynamics. Think that will help?
I just found a tutorial on making cone shapes with foam so the process to cut and glue the top semicircle at the top of the front end to meet the roof line looks fairly straightforward.
https://youtu.be/QKPtQksKBxM
The FoamStream does tow very easily … like nothing is there … My old square Jayco towed like a Barge in molasses … ugh !!! Shape is everything … :thinking:
The extra money spent on foam is well worth the weight savings and lack of rot. Keep keeping an eye on FB marketplace and craigslist and something will popup sooner or later.
Another possible source if you haven't already checked is building supply houses. The local one near me was $7 less a sheet but you had to buy 10 sheets minimum, at the tie I found this out, I only needed one sheet. But when I start my next build I will be going there.
Another option is talk to any contractors that you might have in your network. They may have leftover/partial sheets they can give you. I managed to get some chunks (under half sheets) that I could use for shelves or braces.
Folks keep bringing up rot with wooden teardrops. It's malarky. A properly built wooden teardrop is no different than a properly built wooden house. They don't rot.
Now... if you make the mistake of using OSB in the floor, and it gets wet, it's oftentimes called rot. And it's not. It's wet OSB.
:thinking:
You May find a search for (Orange peel pipe cap) Handy for a shape like that.
After a LOT of FB Marketplace searching, I found a bunch of unused 3" Foamular 250. A contractor accidentally ordered two times what he needed for a refrigerated warehouse, and was selling it for $40 a sheet. Two inch xps is $39 a sheet locally. So I picked up a dozen sheets. I'll lose two inches of interior space each way, but this stuff is R15 and quite strong/rigid.
What can rot will rot. What is inert will stay inert.
I agree a properly built wood trailer can last if properly built. How do you know it is properly built though. Most people here are not professional builders. Foam gives you that extra bit of piece of mind knowing that if there is a leak (and there is not) that it wont be a expensive repair next spring.
I use OSB for my floors, 3 years and many a water crossing and still not soggy. It can't get soggy if it don't get wet for long periods of time. Why because it is protected by foam. Just my two cents... :thumbsup:
Video of river crossing:
https://youtu.be/q03JboEM4o0?t=518
Folks keep bringing up rot with wooden teardrops...
Me thinks the rot I've seen in trailers, RVs and teardrops, is mostly due to neglect. If you get some moisture in your TD make sure you let it dry out before storage. Even with George's foamie, if he buttoned it up after a trip without letting things air out eventually the smell might get a little too much. Mold will grow on foam if neglected. ****, mold will grow on almost anything if neglected. After a trip open the windows, park the TD in the open air/sun, and run the ventilation fans for a day or so.
I have non closable vents to keep me alive when I am sleeping with the door and windows shut. It is that air tight. It follows me down dusty roads and if dust don't get in water wont get in. The only way water is getting in is me breathing, or I leave a window/door open. The vents do their job just fine for airing out in storage.
I was always afraid of building a teardrop and having it rot. I have known of, and heard of many that have deteriorated over a winters nap because they leaked. Only takes once. Then I heard of foamies and my worries were over... :thumbsup:
Since my first build I don't even consider installing a roof vent. Just a bad idea if you want to keep the water out. Plus you don't get moisture drips on your bedding while you sleep and night. :thumbsup:
:thinking: Okay, I'll put in my 2 cents.
A lot depends on the owner/builder. If a teardrop is built right, stored right, and cared for properly, it should last a long time, regardless of whether it is made from foam or wood. But, like George said, most of us are not professionals.
People tend to over-build and not take care of it once it is built. Foamies are a little more forgiving of that. What people do with their teardrop, what they put in it and into it, can also add to the problem. Think poorly installed vents, windows and doors, also added in air conditioners, ovens, heaters. Teardrops aren't meant to be a fifth wheel nor a motor home. They are meant to be one step above a tent and most of us are very, very happy with that.
if you follow what is explained in the foamie threads, I too believe that a foamie will end up being lighter, less expensive, less likely to rot and generally more carefree.
“ They are meant to be one step above a tent and most of us are very, very happy with that.“ … :D
New posts
