The other day I was in our local thrift store and spotted an old tower style desktop computer. The store must have found an old monitor and keyboard and tested it because they claimed it worked, and that it had an AMD athlon CPU, 320 Mbyte RAM, 28 GB Hard Drive, and that Windows 98 SE was installed! They wanted $20, so naturally I snapped it up! Got it home, took out the power supply, and threw the rest in my junk pile.
The power supply is overkill, but it was the last critical piece I needed for the rock tumbler I'm making for Shelly for Christmas!
That old drill draws about 2.5 amps and I was planning to make an old-school "linear" power supply (back when I first made them, we just called them power supplies), but I would have used the last high current voltage regulator in my junk pile, and they are getting hard to find! With the computer supply, I plan to use the 3.3 and 5 volt rails, which just about matches the high and low speeds that she wants to run the tumbler (for her jewelry making hobby).
For anyone interested in using these old supplies, some of them, including this one, need a load on the 5 volt rail to run correctly. Folks in Youtube land have used power resistors. However, I discovered that it works to re-wire the internal fan to run off of the 5 volt power. The fan is enough of a load. The fan runs slower (was designed to run off of 12 volts), but since the tumbler will be drawing much less current than the computer did, the components shouldn't heat as much anyway. Also, the fan runs quieter, but with the drill gears grinding away, that's not an issue.
I have another old computer from the same era, and I've been planning to use that power supply as a bench supply someday. For that one, I'll use the +12, +5, +3.3, -5, and -12 outputs, and probably hang volt meters and other nifty do-dads from it too.
