This is the first of many questions; I am clue less about trailers. I'm thinking of building something Winter Warrior like. 5' 9" x 10'. I hope to keep the expenses down. Thinking that the finial build weight to be < 2000 lbs. I am assuming the trailer body is the structure that supports the load and the frame transfers the load to the axle and hitch in this case.
For the chassis start with either HF 4X8 1195 or 1720, and not widen it at all.
Replace the axle with Galvanized Boat Trailer Axle 67 inch 3500 lb Square by Dexter. https://www.boattrailerparts.com/Ga...e-67-inch-3500-lb-Square-by-Dexter_p_829.html
The website says it's a 2x2x1/4" axle tube, and spring seat measurement: "Will safety accommodate 49 inches to 54.5 inches". The axle has brake flanges for the future addition of brakes.
For your wheels and tires, replace with Taskmaster 5.30-12 Bias Trailer Tire with 12" White Mod Wheel - 5 on 4-1/2 . These are rated for 1,050 lbs at 80 psi and speed rating of up to 81 mph. https://www.etrailer.com/Trailer-Tires-and-Wheels/Taskmaster/TTWAS53012WM45HP.html
Add a 2x2 tube from the hitch to back under the frame.
This would give me a trailer to build on for about $950 - $1050 including a spare tire, or less if on sale.
1 Is my assumption correct?
2 Does this sound feasible?
Take care............."Stay Safe"
