Windows
TheMuffinMan-TNT
New Member
Joined
Mar 17, 2024
Posts
3
I'm looking at windows for my DIY camper build, I'm looking for an insulated/double pane window with a screen built in or at least a window that I can add a screen to in order to keep the bugs out. Ideally they'd be emergency exit windows as well. I was looking at the Recpro 36x20" egress window but it's not insulated.
My build will be a bit larger then a teardrop but it's hard to find DIY camper forums and figured someone here might know where a good source of windows would be?
None of the hundreds of windows available on Amazon appear to be either double pane or insulated, although there are kits for making your own insulating cover—basically a sheet of quilted material to attach to the frame via Velcro or magnets. Covers might actually be preferable to double-pane even if the latter were available: you could make them with a long apron that directed any cold air from its backside on down past the occupants. As regards Amazon, I’ve had good results with both Outprize and Gampro brands.
New posts
