http://www.walmart.com/ip/Mainstays-3-Piece-Cookie-Sheet-Set/10174458?findingMethod=rr. Plus two pieces of 1/2" oak (painted black) screwed to the cookie sheet and also to the wall frame to support most of the negligible weight , then foil-taped in place. The boot and cookie sheet assembly were screwed and taped together before taping to the A/C.
How did you attach the Speedi-Boot to the back of the AC unit?
Do you have any kind of air flow around the coils in the AC unit (into and out of the vents on the side) or is the air stagnant? Do you have any kind of air flow around the coils in the AC unit (into and out of the vents on the side) or is the air stagnant? Answer: The ambient air in the galley (whether hatch is closed or not) is supplied thru a screened 6" dia vent (also serves to ventilate the gas fumes and/or battery gases in that area) next to the chassis cooling louvers (90% uncovered by framework and tape). Since all the exhaust is directed away from those louvers, and cannot be reabsorbed by them, the unit should run cooler than one exposed to a hot breeze back feeding it. I just need to extract the exhaust faster, more completely, to lower the temp inside the ducting. Theory is good, but the execution is lagging.
