This'll do...
Moderator: 2bits
This'll do...
Postby bg » Tue Aug 03, 2010 12:59 pm
Picked this up off of craigslist yesterday:
1978 Shasta 160 pop-up
If nothing else, It'll make a good base when I decide I'm ready to build something, but for the time being it should satisfy my itch to camp.
Bobby(, Kim & Wayne)
bg
Postby Miriam C. » Tue Aug 03, 2010 1:13 pm
:thumbsup: :applause: It'll do till you get what you really want....
Postby S. Heisley » Tue Aug 03, 2010 3:23 pm
+1
...And you can get a few more states colored in on your map! :D
Postby Arne » Tue Aug 03, 2010 3:36 pm
If I got one of those, I'd throw away the canvas, build some fold-able hard walls, and have a really neat, leak proof, camper.
It would be smaller, but I don't need all that sleeping space for me and the dog.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby bg » Wed Aug 04, 2010 1:19 am
If it were in better shape, I'd probably put some effort into a hard sided camper conversion, but there's plenty of hidden and not so hidden rot, as well as just the issues you would expect fold from a 30 year trailer.
bg
Postby Todah Tear » Sat Aug 07, 2010 8:14 am
This will make an interesting restoration. When do you plan to be done?
Todah
Todah Tear
Images: 282
Postby bg » Sun Aug 08, 2010 10:38 pm
Funding/workshop space permitting:
Rip the popup off of it,
Blast the frame and give it a good coat of paint,
Save the sink/stove/icebox/bed cushions/power converter and awning
Add some stabilizer jacks, and build a modified version of Glen-L's Sequoia
But for now, I'll just use it for what it is, a cheap popup camper.
bg
Postby Woodyperk6 » Mon Aug 09, 2010 9:25 am
Bobby, that's great. Will you be bringing it to Loyd Park?
I looked at the Sequoia plans and thought they were pretty cool.
Woody & Tammy
One day closer.
Woodyperk6
Images: 5
Postby bg » Mon Aug 09, 2010 1:22 pm
I should have it at Loyd Park.
I've been looking at the sequoia plans for years. I just want it a bit wider and taller(Full standy) than the stock plans.
bg
pop up camper
Postby Dulcimer Man » Tue Aug 10, 2010 3:15 pm
bg wrote:Funding/workshop space permitting:
I had a popup that had a bad top so I removed the topbeds and canvas and saved the whole bottom part. I framed up the wall and top with 1/8 in plywood outside and inside, made shelves, installed a small fridge. Then on the outside I would lay a heavy coat of paint and lay muslim cloth in the wet paint then coat over that with more paint. When I had finished the top and sides like that it was just like fiberglassing it, I have not had a leak anywhere. I retained the origanial door. Dulcimer Man
Dulcimer Man
Postby planovet » Tue Aug 10, 2010 4:01 pm
bg wrote:I should have it at Loyd Park.
It will be different seeing you in that but at least you will be camping! :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby 2bits » Sun Aug 15, 2010 9:34 pm
Hope to see you out there Bobby!
Thomas
2bits
2bit Member
Return to South Central
