Anyone in the San Antonio area with a homebuilt TTT?
Moderator: 2bits
Postby *Inside » Tue Nov 24, 2020 9:56 pm
I'm working on building my own and I'd like to see some home built trailers in person. I'm looking to do aluminum side panels and am interested in seeing how all the sealing trim works.
*Inside
Re: Anyone in the San Antonio area with a homebuilt TTT?
Postby capnTelescope » Wed Nov 25, 2020 6:30 pm
I'm up in Round Rock, if you're ever headed north. You can see the famous CNC Build, otherwise known as the B&B.
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby 2bits » Thu Nov 26, 2020 9:50 pm
Check out "Build Journals" section. This is where people detail their builds as they do them, step by step, this section was instrumental in answering many of my questions and giving me new ideas!
http://www.tnttt.com/viewforum.php?f=50
Thomas
2bits
2bit Member
Postby *Inside » Fri Nov 27, 2020 11:26 am
I've definitely seen a lot of build journals, but I've only seen 1 teardrop trailer in person :)
*Inside
Postby Sparksalot » Fri Nov 27, 2020 4:34 pm
I’m in Buda, and have a woodie.
Capn telescope has a nice tear for sure.
Sparksalot
Images: 687
Postby capnTelescope » Fri Dec 04, 2020 12:24 pm
Sparksalot wrote:I’m in Buda, and have a w**die.
Strange, Buda never affected me that way.
Sparksalot wrote:Capn telescope has a nice tear for sure.
Aww shucks. Thank you, Sparky. I like yours too.
Brad
capnTelescope
Images: 368
Postby DJ Davis » Wed Dec 30, 2020 2:43 pm
Inside,
I'm in EEN SA-TX off of FM 78. Contact me if'n ya want a look at mine with PMF covering.
DJ
DJ
They say "What doesn't kill you makes you stronger." I've noted that if it doesn't kill you, it waits patiently for another opportunity.
DJ Davis
Postby *Inside » Sun Aug 22, 2021 7:37 pm
Hey DJ - just saw your post.
I'd like to see your trailer - are you still in SA?
*Inside
Postby DJ Davis » Mon Sep 20, 2021 11:00 am
Yes, I am. I haven't checked this thread in a while. Let me know when you'd like to stop by. I'll follow this up with a private message.
DJ
DJ Davis
Return to South Central
