Deep Fried Prime Rib.
Postby Kurt (Indiana) » Sat Dec 22, 2007 11:51 pm
I know this has been discussed on the one forum or another, but when it comes to putting a $70.00 Prime rib into the hot oil, it's a little un-nerving.
We did a Turkey for Thanksgiving and it was fine, but my wife is "freaking out" about the prime rib.
Anyone have any good or bad stories about deep frying a Prime rib??
I personally can't see a problem since it's only "heat" applied to the meat but it's new territory and a little scary considering the price of the meat.
We'll see what happens and I'll let you all know.
ps. my mouth is actually watering as I'm writing this post.
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
Postby Nitetimes » Sun Dec 23, 2007 1:02 am
I dunno, you're skeerin' me an I won't even hafta go hungry if ya screw it up!! 8) :lol: :lol:
Good Luck!!
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby dmb90260 » Sun Dec 23, 2007 2:04 am
I would go to the Cajun Injector site and ask there. The turkeys do fine but the only dense meat is the breast and it cooks from the inside and outside.
They do recommend injecting some meats but I do not recall any deep frying, just inject and normal roast but I could be wrong about that.
Dennis
Join the Kenskill Karavan at:
http://autos.groups.yahoo.com/group/kenskill_karavan/
Real Men cook with Black Iron
The Buzz In the Dale: The Buzz In The Dale
dmb90260
Titanium Donating Member
Images: 134
Postby Dean in Eureka, CA » Sun Dec 23, 2007 12:46 pm
My fail safe method is to use the deep frier burner as a heat source to season big iron...
Not to disuade, but you simply can't go wrong with a probe cabled digital thermometer, a bag of water softener rock salt, a bag of briquettes and a dutch oven.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby dmb90260 » Sun Dec 23, 2007 3:59 pm
Dean in Eureka, CA wrote:My fail safe method is to use the deep frier burner as a heat source to season big iron...
I have tasted Dean's rock salt method, it is probably better than deep frying. :D :D
Dennis
dmb90260
Images: 134
Postby Kurt (Indiana) » Sun Dec 23, 2007 5:02 pm
Here is a link that I've been looking at. I have found several with similar recipies.
It seems very straight forward. The temperature is in th same range as turkey and the minutes /pound are very similar too.
CRA2023 Web Site
Kurt (Indiana)
Images: 178
Postby dmb90260 » Mon Dec 24, 2007 2:39 pm
looks good to me. The only thing I would be concerned about is the thickness of the cut which is not much of an issue with turkey.
You may have to get a small cut for a test drive to convince your SO but after the first time she may love it. Bon Appetit, :applause:
Dennis
dmb90260
Images: 134
Postby Dean in Eureka, CA » Thu Dec 27, 2007 9:09 am
So Kurt,
How'd your deep fried prime rib turn out???
(I still have mass quantities of peanut oil stashed away in the shop)
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Kurt (Indiana) » Thu Dec 27, 2007 9:41 am
Dean, actually, we decided, at the last minute, to use the convention method due to some timing and travel problems.
:cry:
The excitement still awaits. :R
I still think it will turn out OK, just have to wait for the right moment. :thumbsup:
Last edited by Kurt (Indiana) on Thu Dec 27, 2007 10:01 am, edited 1 time in total.
CRA2023 Web Site
Kurt (Indiana)
Images: 178
Postby Dean in Eureka, CA » Thu Dec 27, 2007 9:51 am
Hmm... Well those jugs have about 1/4" buildup off sawdust on 'em, guess it won't hurt to let it go until it gets to the 12" mark. :lol:
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby caseydog » Thu Dec 27, 2007 10:31 am
You can also pack the whole roast in rock salt like a salt shell.
And, here in the south, they can deep fry ANYTHING. :lol:
Personally, I would worry about the outside cooking too fast, and the inside staying raw and cold if you deep fry it. Remember, the goal in cooking turkey is to get it well done all the way through quickly, because it does not have a lot of fat. The faster you can get it cooked, the juicier it will be.
With a fatty beef roast, you want to cook it slowly. That just doesn't sound like deep frying material, to me.
That's my $.03 (inflation).
CD :D
My build journal is HERE
caseydog
Images: 515
Postby DRYVEM » Thu Dec 27, 2007 5:44 pm
Dean in Eureka, CA wrote: a bag of water softener rock salt,
Just my .02 but I would not use water softener salt. Here is an excerpt from Cargill Salt .com.
Can you use softener salt with food, such as canning or with meat packing?
Although water softener pellets may be made from food grade salt, the pellet press process, itself, does not meet the criteria required to call the finished pellets "food grade". Therefore, direct application of pellets in food processing is not recommended. Other water softening salt products like solar salt, rock salt and brine blocks are not recommended for food application for the same reason.
Barbara
Barbara
Proud owner of a 2010 Martin Built Teardrop
DRYVEM
Postby caseydog » Thu Dec 27, 2007 7:44 pm
Barbara
Actually, there are two forms of WS salt -- pellet and granule. The Granule form is like rock-salt for de-icing, but cleaner. I would think that ice-cream making salt would be the cleanest, but I'm not sure.
The pellet form is better for water softeners, though.
caseydog
Images: 515
Postby depatty » Thu Dec 27, 2007 7:45 pm
Barbara
If it's good enough to go in the water, it ought to be good enough to cook with.
My $0.02 worth...
Dave
depatty
Images: 175
Postby Dean in Eureka, CA » Thu Dec 27, 2007 11:37 pm
Barbara,
Thanks for your concerns, but I really think that's the salt company's way to get you to buy the more expensive product.
I too had concerns until I started asking around...
Dean in Eureka, CA
The Fogcrawler
Images: 69
