How can I get more heat out of the stove? (yes, I did turn it all the way up)
Miriam C. wrote:The temperature of boiling is higher at altitude so you need more btu's. You might find a stove specific for use in the mountains especially in winter. You might also look for an electric solution to getting your coffee made. I hear the campfire works well also.
coreyjhen wrote:Miriam C. wrote:The temperature of boiling is higher at altitude so you need more btu's. You might find a stove specific for use in the mountains especially in winter. You might also look for an electric solution to getting your coffee made. I hear the campfire works well also.
Actually, the boiling point decreases with elevation. The boiling point of water at 9,000 feet is about 194-195ºF instead of the 212ºF of sea level. The most likely explanation for being unable to boil water on this stove is that there is simply not as much oxygen for the fuel to combine with at high elevations (less atmospheric pressure = less oxygen available) and the fuel is not combusting as completely as it would at lower elevations. A 20,000 BTU stove will be affected by the same percentage as a 10,000 BTU stove, but the presence of twice as much fuel in the first place will probably allow you to generate enough heat to boil water. If you want your food to cook all the way through on top of Pike's Peak you may want to consider a pressure cooker.
The boiling point is the temperature at which the pressure of the water vapor equals atmospheric pressure and the bubbles of water vapor are able to break through the surface and escape into the air. If the atmospheric pressure is less, the temperature required for water to boil is less (Table 1). Therefore, cooking food in water boiling at this lower temperature takes longer. A "3-minute egg" will take more time. Also, a bowl of boiling soup is not as hot.
