Teardrop for sale Philladelphia PA area
Postby len19070 » Thu Jul 13, 2006 5:26 am
Offering up my last Bear Bones Trailer. (for the year)
http://www.geocities.com/len19070/Bare_ ... ilers.html
Frame specs;
4 x 8 TRAILER SPECS[/b]
purchased from Tractor Supply
built by Carry-On Corp model: 4x8 NF
SKU 1000215
Frame dimensions
frame width=49" outside angle 48 7/8" inside angle
frame length=96 1/4"
tongue length from from cross member= 36.5"
deck height= 13.5"
cross member spacing from front cross member is:
14", 44", 74"
Coupler size is 1 7/8"
Coupler height is 12 1/2" with standard tires
Trailer comes wired with tail lights, clearance lights and a license plate
holder.
Safety chains are included.
G.V.W.R. = 1500 LB
Material
frame is 2 x 2 x 1/8 steel angle
tongue is 2 x 3 x 1/8 steel tube
tongue brackets are 2 x 2 x 3/16 steel angle
fender height= 23"
fender length= 24"
Dexter Axle #2K6047
hub face to hub face= 60"
spring center to spring center = 47.25"
axle placement is 59.25" from front cross member
and 37" from rear cross member
hub spacing is 5 x 4 1/2
Tires are 4.80 x 12 load range "C"
Kenda Loadstar tire (or equivilent)
990 lb capacity at 90 psi
There is 3" clearance between tire sidewall and
frame
Happy Trails
Len
len19070
Images: 24
Postby pbb » Thu Jul 13, 2006 6:57 am
Hi Len. The link isn't working for some reason. Is the the teardrop that was on Route 420 this weekend? - PBB
pbb
Images: 15
Postby len19070 » Thu Jul 13, 2006 4:55 pm
Yep, thats the one.
Happy Trails
Len
len19070
Images: 24
Return to For Sale/Wanted
